Risultati da 1 a 7 di 7
Discussione: Extrude Snip
    Data Registrazione
    September 14, 2020
    Messaggi
    23
    Ora locale
    07:36 AM
    Extrude Snip
    Hi all, I am currently working in a family > generic model and trying to extrude support on the side of this small structure. However, the two beams on the side are supposed to be slightly longer and taller in extrusion than the middle and left ones. Is there a way to only grab the two on the right and slightly raise their "Extrusion Ends" because all 6 are currently at the same heights? Thank you
    Anteprime Allegate Anteprime Allegate Extrude Snip.PNG‎
    Data Registrazione
    September 14, 2020
    Messaggi
    23
    Ora locale
    07:36 AM
    The only way I can think of completing this right now is creating a new extrusion, trace over the two beams on the right side and make that length higher, then to delete the two beams on the right in the original extrusion? It feels like this might be a little too difficult too because I'm dealing with a few 1/4th circles of different radii and random floating centers for the radii. Thank you!
    Data Registrazione
    Messaggi
    3,239
    Ora locale
    07:36 AM
    If all the sketches are in one extrusion, no. You could cut off the excess at the "shorter" portion with a void. You could also create profile families for each shape and then create sweeps using those profiles but that would be starting over.
    Moderator L'avatar di DaveP
    Data Registrazione
    Località
    Messaggi
    3,525
    Ora locale
    09:36 AM
    Examples like this are exactly why I discourage people from creating disparate elements in one Sketch.
    People in our office also tend to sketch Ceilings for multiple rooms in one huge sketch.
    It's not really any easier to create everything in one sketch as opposed to each one being separate, and having everything in one eliminates the possibility to change just one or two.
    Administrator L'avatar di Twiceroadsfool
    Data Registrazione
    Località
    Messaggi
    11,622
    Ora locale
    09:36 AM
    5 Not allowed! Not allowed!
    Citazione Originariamente Scritto da DaveP Visualizza Messaggio
    Putting them all in one sketch also:
    1. Means the tag goes to the centroid of ALL of the rooms (sucks)
    2. Means its "one object" downstream, for Coordination, scheduling, quantifying, etc.
    3. Has the POTENTIAL for needing to destructively edit it later, to split it up.
    There are zero upsides to putting multiple elements in one *thing*. Yuck.
    Forum Addict L'avatar di elton williams
    Data Registrazione
    Località
    Messaggi
    2,881
    Ora locale
    12:36 AM
    Citazione Originariamente Scritto da Twiceroadsfool Visualizza Messaggio
    I can't remember the last time I began working on an existing project where I didn't need to do this. Floors, ceilings, even walls! Grrrr.
    Data Registrazione
    September 14, 2020
    Messaggi
    23
    Ora locale
    07:36 AM
    Thank you! I separated each of the extrusions by height. More time consuming, but less time consuming in a way but naturally works out better in case of other extrusions happen in the future. Thanks
Discussioni Simili
  1. Can't retain position of extrude cut
    Di gpktm nel forum Architecture - Family Creation
    Risposte: 1
  2. Extrude/Create form
    Di byk3bep nel forum Architecture - Conceptual Massing and Adaptive Components
    Risposte: 4
  3. How to extrude a triangular shape? please help!
    Di irfan_77uk nel forum Architecture and General Revit Questions
    Risposte: 8
  4. parametric dims in extrude sketches
    Di madhaka nel forum Architecture - Family Creation
    Risposte: 26
Permessi di Scrittura
  • Tu non puoi inviare nuove discussioni
  • Tu non puoi inviare risposte
  • Tu non puoi inviare allegati
  • Tu non puoi modificare i tuoi messaggi
