Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Dimension Redo - Every Week
  1.    #11
    11,617
    07:43 AM
    Yeah, its deleting them on UNload, so it wont matter how they reload it.
    But i 1000% agree, they should be saving the different versions, in case they need them, for something. But i keep all of the CURRENT ones in one folder.
  2.    #12
    February 20, 2021
    5
    09:43 AM
    I'll check with our BIM manager to see if there is a particular reason we do not keep previous versions of consultant's models.
  3.    #13
    11,617
    07:43 AM
    Theres an echo in here!
  4.    #14
    November 23, 2012
    101
    05:43 AM
    Quote Originally Posted by AtlanticViews View Post
    As I am not in a position to end the dimensioning of columns I guess I will dimension these one last time using the Aligned dimension.
    Thank you for taking the time to reply and to test out other dimensions!
    Well, you can always do what Architects do:
    You can add all the dimensions (that you know you should not) and then put a big general note that all structural dimensions on these plans are general information / suggested and direct the contractor to absolutely not use these dimensions and please refer to S plans for same. And also, to please give us a call if you find any discrepancies, we'll clarify it right away.
  5.    #15
    4,567
    01:43 PM
    Quote Originally Posted by bt.comm View Post
    And also.
    don't forget to also hand transcribe the full drawing number of said other's work into those notes so that you have to revisit and re-issue the set in perpetuity.
  6.    #16
    11,617
    07:43 AM
    3 Not allowed! Not allowed!
    I wanted to circle back on this thread, as i heard back from the Development and QA team at Autodesk, and they have found the cause of the issue:
    Quote Originally Posted by Autodesk Team
    Here are the details. This is caused by the inconsistency between linear and radial dimension internal design.
    For linear dimension, it handles “Unload a linked file" as a special case of dimension references not visible in the current view, while for radial dimension, it handles the unloading as invalid dimension reference, and thus it requires deletion of the radial dimension when unloading.
    We will see how we might improve the radial dimension to follow a similar behavior pattern.
    (emphasis mine)
    So, they didnt have it documented before, but its a minor difference in how the two types of dimensions handle a Linked File being unloaded. Its on their radar now, which is a plus.
    Thanks to the Adsk team for jumping in and looking in to it, after this thread popped up. Its great to find out whats actually causing small issues like this.
  7.    #17
    February 20, 2021
    5
    09:43 AM
    Thanks for circling back to share your findings. It's great to see how fast the Autodesk Team checked this out for you/us!
  1. Dimension within dimension string does not have lock
    By ryntau in forum Architecture and General Revit Questions
    Last Post: July 4th, 2020, 08:33 PM
  2. Dimension strings not adding up to the total length dimension string (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: March 26th, 2018, 03:24 PM
  3. Dimensions: Dimension Movement , Dimension Breaks
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 7th, 2015, 08:15 PM
  4. Dimension & Dimension Text Colours
    By Kristjan in forum Architecture and General Revit Questions
    Last Post: February 11th, 2015, 06:21 PM
  5. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
