Thread: Sloped Conduit
    April 22, 2018
    Massachusetts
    06:24 PM
    Sloped Conduit
    I have a project that requires the conduit under the roof to follow the slope of the roof.
    I created a sloped named reference plane but I found that you cannot draw conduit on a reference plane, only a level and I cannot create a sloped level.
    Any suggestions?
    I have thousands of feet to draw.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    307
    05:24 PM
    While in a section or elevation view, you should be able to align the conduit to a roof plane. Then select the conduit, and move (or modify Offset) to the desired location.
    April 22, 2018
    Massachusetts
    06:24 PM
    I know that I can align it after I draw it, but I have thousands of feet to draw and I just wanted to draw it all in a floor plan view on the slope of the roof.
    January 17, 2011
    2,153
    05:24 PM
    3 Not allowed! Not allowed!
    Rotate a Section, then go in the View. Works like a champ.
    -TZ
    *EDIT* Let me clarify: Rotate a Section while in a Section/Elevation View, where it's faced "down" but at the proper degree slope of the roof.
  1. different conduit colors
    By Ning Zhou in forum MEP - General
    Last Post: February 9th, 2017, 03:01 PM
  2. Tag how many conduit are in a run
    By cbaze in forum MEP - General
    Last Post: June 23rd, 2016, 11:05 AM
  3. sloped wall joined to sloped roof
    By sohn in forum Architecture and General Revit Questions
    Last Post: May 14th, 2016, 11:12 AM
  4. Conduit Run Schedule
    By cphubb in forum MEP - General
    Last Post: August 10th, 2015, 02:51 PM
  5. Sloped glazing in sloped wall
    Last Post: September 7th, 2012, 08:12 PM
