Thread: Center of Gravity
    January 12, 2015
    01:10 PM
    Center of Gravity
    Hi, apologies if this has been asked before but I couldn't find much when I searched the forum but does anybody know of an add-on for finding the center of gravity for a Revit precast family in 2021?
    I've seen an add-on called CG Finder for 2018/2019/2020 but there doesn't seem to be one for 2021.
    Thanks.
    December 11, 2010
    Astana
    324
    07:10 PM
    The center of gravity can be found using the Dynamo. What result do you want to get?
    January 12, 2015
    01:10 PM
    Thanks for the reply. I need it for some precast concrete units, for presentation purposes and to help locate lifter positions etc.
    CG Finder was very quick and easy to use, just click CGFinder, click the unit and it would place the COG on whatever view needed.
    I've never used Dynamo, would it be easy to locate it this way for a Dynamo novice?
    Kingdom of Denmark
    4,305
    03:10 PM
    Dynamo comes OOTB with a "Centroid" node, so it should be fairly simple to find the point, and place a family at that point.
    11,691
    08:10 AM
    2 Not allowed! Not allowed!
    Just beware that Centroid and CoG arent the same thing, as material density can play a factor. If Material Density is CONSISTENT everywhere, then you can use the centroid. But if the material density varies across the geometry of the panel, it wont be the same as the Centroid. Just something to be aware of.
    December 11, 2010
    Astana
    324
    07:10 PM
    @moorz123 You can try copying the installed CG Finder from the 2020 addins folder* to the 2021. Some simple plugins work after that in the new version of Revit.
    *C:\ProgramData\Autodesk\Revit\Addins\[Version]
  1. Gravity/sloped wastewater systems issues
    By Iberkim in forum MEP - General
    Last Post: April 29th, 2020, 12:05 PM
  2. BIM & Beam: Gravity Analysis in Revit 2016
    By BIM & Beam in forum Blog Feeds
    Last Post: May 15th, 2015, 12:15 PM
  3. Revit OpEd: Insert using Auto-Center to Center
    Last Post: May 30th, 2014, 05:15 PM
    Last Post: October 11th, 2013, 03:45 PM
    Last Post: September 16th, 2013, 02:15 AM
