Thread: Aligning family in a project
    December 14, 2011
    68
    02:24 PM
    I have created a clamp family, the clamps can be at varying heights and I would like to insert into a project and use the align command to control the heights of the clamps instead of say using a instance parameter is this possible?
    I can only get the whole family to move up and down using the align I would like to align each clamp at different levels if possible?
    3,243
    06:24 AM
    Should be possible. You might have to revisit how you've constrained them already. It requires an Instance parameter driven dimension and reference planes assigned to Strong or Weak IsReference status at a minimum, to get the grips. The Align tool might require using the TAB key to cycle between the shape handle and reference of the element. The shape handle will generally move the part while the reference will move the entire family. There are a lot of possible variables. Give it another go and post your family if you still don't get what you're after. That way someone can see what you've already done...and point the way.
    December 14, 2011
    68
    02:24 PM
    I have attached an example, when I load the family into a project and align the CHS it moves the whole family.
    3,243
    06:24 AM
    Change what the dimensions are referencing, not the Level. Use the reference plane that lies beneath the level. This will display the grips in section or elevation and allow the alignment you're after.
    December 14, 2011
    68
    02:24 PM
    I can't get it to work probably as it is a nested family.
    3,243
    06:24 AM
    This works for me, I can align them independently (Revit 2019).
    December 14, 2011
    68
    02:24 PM
    I have just figured it out before I had it locked to reference level instead of reference plane
  8.    #8
    December 14, 2011
    68
    02:24 PM
    Now I get it. Cheers !
    Last Post: October 6th, 2016, 04:45 AM
  2. Revit opens a new instance of family each time you edit the family from the project
    Last Post: May 24th, 2016, 06:57 PM
  3. Can't change family origin point, family loads into project as hidden lines
    Last Post: February 1st, 2013, 03:51 PM
  4. Aligning Linked CAD file to Revit Project?
    By lukewallace1990 in forum Architecture and General Revit Questions
    Last Post: November 23rd, 2012, 08:08 PM
  5. aligning bottle trap family
    By Fekoloid in forum MEP - Family Creation
    Last Post: October 20th, 2011, 05:17 PM
