Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: How do i manipulate a pdf to get a desired margin size ??
    March 29, 2021
    16
    05:28 PM
    HEY EVERYONE
    Well it seems I'm here with the classic Revit forum question regarding PDF MARGINS AND PRINT SETUP.....
    I just want to be able to control the size of my margins on a D size sheet. I have lost count at how many hours I've spent trying to set this sheet up perfectly. Revit always seems to generate a random margin of its own - regardless of your desired sheet size. This just needs to look good in a PDF. That is the main goal. 1.5" margin on the left side, .5" on all other sides...
    List of things I've tried:
    resized my title block smaller to accommodate for actual "sheet size"
    Tried messing with zoom and X Y coordinate dialogue.
    Tried printing "no margins" and drawing another line that measures out to the spec
    In autoCAD this would be no problem....seems like it shouldnt be hard to replicate in BIM software...right??
    1,911
    11:28 PM
    It is not hard at all, make a rectangle in your title block the exact size at your paper size and offset that line to where you want it to end up in your PDF, so the 1.5" and 0.5", but also keep the outer line.
    Print your PDF's at 100% and centered and no margin and you should end up with what you want.
    2,894
    07:28 AM
    We use xrev for plots which can automatically select sheet size based on titleblock extents. Not sure on the software programming but if any labels or invisible lines are outside a known sheet size, things get screwy, even when set to centred / 100% etc.
    March 29, 2021
    16
    05:28 PM
    Hey thanks for responding guys!
    @Robin - That is the workflow that has got me closest to my desired results. heres and image that shows its zooming to those lines on 3 out of 4 sides....mystery is the 4th sideClick image for larger version.
Name:	snip for forum.JPG
    I have checked reveal hidden elements and the block is clean.
    thanks for taking a look!
    Eddy
    1,911
    11:28 PM
    Looks to me either something is off with your titleblock size or there still is a margin defined at the top in your printer settings.
    Any change you can post an empty project with just 1 sheet so we can gave a look ?
    March 29, 2021
    16
    05:28 PM
    Yeah ill attach a blank title block!
    as far as i know there is now way to adjust the margins on that side besides adjusting the x axis....Ive tried the manual input and once i get the top sqaured away another margin pops up on another side.
    I explored the sheet size issue a bit...here what i know. The sheet is standard D size. I set it up 36x24....I use D (bluebeam is my pdf driver) Currently have another box around the titleblock that denotes the margin. Ive tried shrinking it as well, but the same issue persists, an unknown margin always reveals itself.
    One more note - the end goal is just a good looking PDF, not a large format printed sheet. Thats later down the road, for now im just trying to get it to look right when you view the PDF.
    I would send you my .rfa titleblock but idk how to attach that here lol
    March 29, 2021
    16
    05:28 PM
    i am using "offset from corner" because using center makes the block much smaller on the page.
  8.    #8
    11,659
    04:28 PM
    So, you know this titleblock is 100% completely the wrong size, correct?
  9.    #9
    March 29, 2021
    16
    05:28 PM
    nope....explain
    ive tried to offset it to 34x22 as well. to no avail.
  10.    #10
    1,911
    11:28 PM
    Looks to be 38x25" to me
  1. Automatic View Suffix desired
    By aperte in forum Architecture and General Revit Questions
    Last Post: December 31st, 2019, 03:24 PM
  2. Replies: 16
    Last Post: June 12th, 2018, 08:43 PM
  3. Edit Stair Risers to desired dimensions?
    Last Post: May 1st, 2015, 03:08 PM
  4. To manipulate one of two divided surface with adaptive component
    By leeway180 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 30th, 2015, 05:49 AM
  5. margin settings in sheets
    By ikinks in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 08:05 AM
