Thread: copying coupling doesn’t split pipe
    February 10, 2018
    16
    07:03 AM
    Question copying coupling doesn’t split pipe
    im using geberit mapress pipe
    im putting coupling at 60 cm above the floor
    in the levels above i want the coupling to be at same place - 60 cm above floor
    im copying the coupling and paste it to selected levels but it pasting without splitting the pipe. it’s overlapping into the pipe.
    there is a solution for this?
    another question
    when im copying the coupling from level 1 to level 2 the reference level stays at both of them “level 1” instead of changing the coupling at level 2 to be at level 2 reference.
    December 11, 2010
    Astana
    317
    10:03 AM
    1. Use the Split Element, Create Similar or Pipe Fitting to insert a coupling.
    2. In Revit 2020, everything works fine: the fitting is assigned to the nearest level if you copy, or inherits the pipe or duct level if inserted.
    February 10, 2018
    16
    07:03 AM
    1. Now Im using split element and create similar but this process is taking too much time for something that repeat itself so much in my work. i thought may a better way.
    2. im using 2021 and when im create similar to the coupling and put in on the pipe the reference level is the first floor
    December 11, 2010
    Astana
    317
    10:03 AM
    1. Maybe it's time to think about automation with Dynamo.
    2. The fitting takes the level from the pipe into which it is inserted.
    February 10, 2018
    16
    07:03 AM
    I definitely needs to learn dynamo
    thanks for your help
  1. Pipe fitting color doesn't match my pipe
    By Rocha81 in forum MEP - General
    Last Post: March 28th, 2019, 12:48 PM
  2. copying revit fab pipe from one drawing to another
    By Ramon1219 in forum MEP - General
    Last Post: June 7th, 2018, 03:00 PM
  3. Eccentric increaser pipe coupling
    By Pavan1509 in forum Architecture - Family Creation
    Last Post: July 6th, 2016, 03:19 AM
  4. Pipe Insulation doesn't allow cut material?
    By tzframpton in forum MEP - General
    Last Post: February 3rd, 2014, 08:46 AM
  5. Replies: 3
    Last Post: January 6th, 2012, 01:53 AM
