Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: revision management
  1.    #11
    3,549
    08:46 AM
    It's not easy to find, but from the Title Block family, in the Project Browser, go into the Schedules grouping. It'll probably be called Revision Schedule
    Open that View
    In the Properties Palette, click on the drop-down (it probably says Family: Title Blocks) and select the Schedule from the list
    That will bring up the Properties of the Revision Schedule itself
    Go into the Appearance Tab and change the Height from Variable to User Defined
    After all that, you should be able to see the elusive blue dot that lets you set the number of rows
  2.    #12
    1,939
    03:46 PM
    Lol, man I overlooked that.
    The last time I did anything with titleblocks was a long time ago, so forgot about that option.
  3.    #13
    3,549
    08:46 AM
    Obscure knowledge!
    That's my specialty.
  4.    #14
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    311
    01:46 PM
    congrats Dave, you succeed to find to small stuff to change!!
    as Robin said, we don't spend a lot of time to modify the titleblock after it has been created
    Phil
  5.    #15
    July 7, 2017
    Hernando, MS
    699
    08:46 AM
    Another note on the Issued check box: it pretty much locks everything related to that revision. All revision clouds on that revision get locked so they can't be edited or deleted. The tags can still be changed, moved, added or deleted, but the cloud itself stays as-is.
    Last Post: June 5th, 2017, 12:45 PM
  2. Bimlink to Excel for Revision Management
    By Versiamo01 in forum Architecture and General Revit Questions
    Last Post: June 19th, 2015, 02:09 AM
  3. revision clouds in legend views do not generate revision schedule entries
    Last Post: July 1st, 2013, 10:39 PM
  4. Sticky Notes: Revit Intermediate - Revision Management
    Last Post: September 4th, 2012, 12:15 PM
  5. Sticky Notes: Revit Basics - Revision Management
    Last Post: August 31st, 2012, 04:45 PM
