Results 1 to 2 of 2
Thread: Why Dimensions are going Crazy?
    November 12, 2012
    Bengaluru
    44
    08:43 PM
    Hi Members,
    There is a dimension, which is labelled and I have given a value but when I select that dimension in the working space its value is 0.1 mm less, I tried multiple time but the value is 0.1 mm less always.
    Has anyone faced this earlier, is this a bug or is it repairable issue or will it cause any issue in future.
    This is really
    Attached image for reference.
    Waiting for any response on it.
    Thanks.
    December 11, 2010
    Astana
    323
    09:13 PM
    Have you checked the rounding of project units and dimension?
  1. RTC: Heres to the crazy ones
    By RTC in forum Blog Feeds
    Last Post: October 30th, 2016, 09:45 PM
  2. Crazy dimension
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: August 1st, 2016, 09:58 PM
    Last Post: March 23rd, 2016, 12:15 AM
  4. Angular Dimensions acting like linear dimensions (up-down, left-right only)
    By Jobrowns in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 08:50 PM
