A team was trying to override the appearance of the DWG layers after linking the file to their Revit project. Usually the reason for this not working is elements are not assigned to color or line pattern BYLAYER in the DWG.
In this case it wasn't working because the DWG was not within View Range's Primary Range, it was in the View Depth zone. Projection and Cut linestyles work inside the Primary Range and the linestyle is used for elements within View Depth.
Good catch Mia!
