Thread: CutePDF Printing Error
    April 7, 2021
    12:01 AM
    Unhappy CutePDF Printing Error
    Hi folks, I just started having this issue when printing a Revit sheet to CutePDF. See 2 images of what my title block should look like and how it ends up printing. I've tried un/reinstalling both CutePDF and Adobe Acrobat Pro DC. I run Revit on my Mac using Parallels. I even recreated the title block. Everything is in Arial, so I have no idea why this is an issue. Any ideas?
Name:	Title Block - Correct.png
ID:	40344Click image for larger version.
Name:	Title Block - Incorrect.png
    1,895
    06:01 AM
    Wasn't there an issue with Revit and a Windows Update screwing with PDF's?
    Yep, more info here:
    https://knowledge.autodesk.com/suppo...-in-Revit.html
    3,535
    11:01 PM
    April 7, 2021
    12:01 AM
    Thank you, Dave and Robin! A Windows update was indeed the culprit! Uninstalling it did the trick.
  1. Overlaping views printing error
    By shyock in forum Architecture and General Revit Questions
    Last Post: March 9th, 2017, 10:58 AM
  2. Printing to Adobe Error
    By WVReviter in forum Architecture and General Revit Questions
    Last Post: August 17th, 2016, 03:18 PM
  3. Acrobat PDF & Revit printing error
    By iru69 in forum Architecture and General Revit Questions
    Last Post: July 27th, 2015, 06:04 PM
  4. Printing to PDF low quality/ possible error
    By designnit in forum Architecture and General Revit Questions
    Last Post: April 29th, 2013, 01:51 PM
  5. Printing error with curved surfaces
    By jmk in forum Architecture and General Revit Questions
    Last Post: March 14th, 2013, 05:27 PM
