Results 1 to 10 of 12
Thread: Solve the problem of multi-materials non-existing tread in stair
    April 16, 2021
    6
    01:07 PM
    Smile Solve the problem of multi-materials non-existing tread in stair
    have a question about getting the solution to adding multi-materials for Tread in the Monolithic stair due to it consisting of such as plaster, sand, and marble ( not one material ) how can adding more materials
    Please help me
    April 16, 2021
    6
    01:07 PM
    Please Help me
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    428
    01:07 AM
    you have the options to adjust with the Monolithic Material (Lets call this the structure or concrete) and then the Tread & Riser Material (you can adjust these individually).
    What I normally do is make the Tread & Riser the overall thickness of the Marble & Adhesive Mortar, & in your Instance, a Marble Material.
    2,897
    11:07 PM
    I create a second stair for the tile that sits on top.
    April 16, 2021
    6
    01:07 PM
    d.stairmand
    That's cool but I need to select more than one material for Tread And Rise ...
    I choose the material of tread and rise from the Materials and finishes box .. there is attached photos explain thatClick image for larger version.
    Would there any way to add more than one material for Tread and Rise ???
    Long Beach, CA
    272
    06:07 AM
    Quote Originally Posted by Hanan Dai View Post
    AFAIK it is not possible to specify more than one material.
    You can though, use the paint tool if you want to change the material on a specific tread or riser -- so you could get multiple materials on a flight of stairs. However, i don't know that you can split face it to use multiple materials on a single tread or riser (i've never tried nor would i want to).
    April 16, 2021
    6
    01:07 PM
    Quote Originally Posted by kingjosiah View Post
    Thanx ...
  8.    #8
    April 16, 2021
    6
    01:07 PM
    Thanx .. kingjosiah
    But I didn't ask you about trying to solve this gap ... sooo thanx again
    If there are any body have the way to deal with this gab ... I am waiting the Solution
    Many thanx
  9.    #9
    Long Beach, CA
    272
    06:07 AM
    Hanan,
    Your end goal is not clear. Can you describe what you are trying to accomplish so that we can best help rather than us trying to play a guessing game? There have been a few solutions provided, but none which seem to suit your fancy.
    Is it graphics or renderings you are after? Do you want to tag/identify the materials? Are you trying to do material takeoffs?
    All that i've heard thus far is that you want multiple materials per tread. So again.....no, there is not a way to specify multiple materials per tread, or per riser. You can choose one, and only one....one for the tread definition and one for the riser definition. So you either model a second stair like Elton suggested, or you paint the tread like i said (see below). Painting the tread will work if you are documenting in 3D; you will not see the multiple materials in plan view. Your best bet in that case is modeling the 2nd stair.
    Jon
    Attached Thumbnails Attached Thumbnails Stair Tread Paint.jpg   Stair Tread Paint Plan.jpg
  10.    #10
    February 24, 2011
    Auckland
    428
    01:07 AM
    Hanan,
    Jon
    I like the way you did the Tread Nosing - Very slick
    Question - Is that just a "Split Face" on the Stair & then a "Paint" Material for the Nosing?
  1. Stair Tread Obscuring Stair Path Arrow
    By Manderson in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2019, 08:22 PM
  2. 2015 use baluster per tread on stair (with no top rail?)
    Last Post: August 28th, 2015, 03:25 PM
  3. Stair by Component - Stair tread profile & detail components
    Last Post: October 17th, 2013, 06:26 PM
  4. Stair Tread number tool - Is it possible to make it work over multi level stairs?
    By darkwing in forum Architecture and General Revit Questions
    Last Post: September 26th, 2013, 11:04 AM
  5. Stair - extra line at tread
    Last Post: June 4th, 2013, 04:30 PM
