Thread: Multistory Stair Railing adjustment
    Senior Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    507
    11:06 AM
    (Revit V2021.1.2)
    Can you help with a question on Railings on Multistory Stairs please? I have a building with 6500mm between floors. Our stairs use 4 risers of 9 treads each to get between floors.
    I have used Multistory Stairs and it seems to be working well. This is good.
    On the three landings the Railing correctly rolls around the corner. This is good.
    But on the actual floor level the Railings stop and start.
    Do you know how I get them to joins up neatly please? Normally I would be able to edit the path in a plan view, but here because the path wraps over itself again Revit wont allow me to edit it.
    Can you help with some suggestions please?
    Thanking you in advance.
    11,694
    08:06 PM
    Are those stair runs set to 'end with riser?' Because my railings don't act like that, and my stringers come all the way to the floor edge.
    January 12, 2011
    London, UK
    590
    02:06 AM
    I found a good explanation about this here: https://www.youtube.com/watch?v=JZQpZTUHa9Y&t=607s
    August 31, 2011
    Sydney, Australia
    507
    11:06 AM
    OK. Thank you both.
    My testing shows no combination of "Begin with Riser" and "End with Riser" allows the inner railing to automatically go around the transition at the floor level (Landings are fine).
    Regardless, I can now edit the path at the top and bottom to bring them together in a multi-story stair. This is good.
    This works fine for a stair with two Runs per floor. My stair has four Runs per floor and so the Railing path loops over itself. This is proving challenging to identify the start and end segments in Edit mode. If you have any suggestions on that I would much appreciate it. Thanking you.
    3,550
    08:06 PM
    Does it help it you change the railing segment to "Sloped" instead of "Host"?
    July 7, 2017
    Hernando, MS
    699
    08:06 PM
    I've only used MS stairs a couple of times, and as I recall this is just how it works. You're only sketching one set of stairs and railings, from one level to the next level, so it doesn't really connect the railings at the actual level since it's not part of the sketch.
    August 31, 2011
    Sydney, Australia
    507
    11:06 AM
    Thank you gents.
    Sloped/Host/Flat made no difference.
    There is definitely two sets of path linework representing the four flights, but I can't successfully modify them. Shame.
  8.    #8
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    309
    01:06 AM
    2 Not allowed! Not allowed!
    Railings on multiple floors is always fun in Revit.
    I always just draw them manually (unhosted). It takes some time, but its very flexible that way.
  1. Stair Landing Elevation Adjustment
    Last Post: December 12th, 2019, 05:50 PM
  2. How to convert a multistory stair back to normal?
    By tiangtiang in forum Architecture and General Revit Questions
    Last Post: March 12th, 2019, 06:47 AM
  3. Multistory Stair Run Tag
    By ScubaMan in forum Architecture and General Revit Questions
    Last Post: August 7th, 2017, 10:44 PM
  4. 3 Run Stair Railing
    By Grumple in forum Architecture and General Revit Questions
    Last Post: September 24th, 2015, 03:33 AM
  5. Multistory Railing Visibility
    By RaiderArch in forum Architecture and General Revit Questions
    Last Post: February 20th, 2014, 03:28 PM
