Thread: Foundation Location Mark
    April 22, 2021
    Virginia Beach, VA
    02:32 PM
    So the building's 473 piles all need an individual identifier mark - eazy peazy - and a location mark. Revit has a built-in Column Location Mark parameter that could easily be scheduled, anyone have a clue how to do this with foundations other than manually entering them all?
    May 14, 2012
    584
    12:32 PM
    Could you use Dynamo to copy the column Location Mark to the foundation Mark parameter?
    April 22, 2021
    Virginia Beach, VA
    02:32 PM
    Thank you CADiva. If it could be done with Dynamo, would that approach depend on a column being at the same grid location? These piles are supporting grade beams or pile caps and many do not have an associated column. If however the system parameter Column Location Mark could be added to the Structural Foundations category - that is exactly what we need.
    I'm not very familiar with Dynamo, would someone who is knowledgeable pipe up and say whether or not it can be done?
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    311
    01:32 PM
    There are 3rd party tools that can generate parameters for X,Y,Z coordinates at a structural foundation's insertion point. That information could then be tagged and/or scheduled. But if you're wanting to display the closet grid intersection, then I would agree with CADiva. Dynamo might be the best solution. The link below would be a good starting point.
    https://forum.dynamobim.com/t/revit-...parameter/4476
    April 22, 2021
    Virginia Beach, VA
    02:32 PM
    Quote Originally Posted by Knitro87 View Post
    Thank you Knitro87, that looks like a good starting point for the guy in our office who's getting familiar with Dynamo. Our ultimate goal is to schedule the location for each pile.
    11,691
    01:32 PM
    A lot of the 3rd party cools are great, if you dont mind making sure your workflow is exactly how they want it to be done.
    We use Dynamo for all of our Field Layout (including slab edges, Piles, foundation corners, partitions, doors, penetrations, etc) because it can be custom tailored for the different outputs we want, in terms of how to run the process.
    Attached Thumbnails Attached Thumbnails 2017-03-25_20-12-16.png   2017-03-25_20-13-18.png   2017-07-14_13-56-33.png
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    468
    07:32 PM
    That looks pretty sweet. Does your automation place the coordinates exactly as shown (without clashing with other coordinates) or do you have to manually review and reposition them as required?
  8.    #8
    11,691
    01:32 PM
    The coordinates are "placed" in parameters in the object. The tags on the views arent necessary at all. You could also just drop a schedule on the sheet, since they are all in Shared Parameters.
    If you WANT the tags though, for us, they have to be manually placed (well, with tag-all) and arranged. Ive seen people building automation to auto-arrange tags, but we didnt get in to it, as we didnt need it most of the time.
  1. Type Mark (and Material Mark) linked to Sheet Number or Name
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: September 11th, 2017, 04:20 PM
  2. Change location mark for Structural Fabric Reinf.
    Last Post: October 16th, 2015, 07:48 AM
  3. Adding Column Location Mark to Multi-Category Schedule
    By tunaogut in forum Structure - General Questions
    Last Post: July 15th, 2015, 02:34 AM
  4. Foundation Location Mark?
    Last Post: August 20th, 2013, 08:45 PM
  5. Manually override the Cut Mark Location of a Stair?
    Last Post: August 4th, 2013, 12:43 PM
