Thread: Viewport name with multiple rows
    April 22, 2021
    07:01 PM
    Question Viewport name with multiple rows
    I created this type of viewport that allows you to choose the rows to be visible. It works perfectly in the family editor. Not so well in the project. What are the possible reasons?
    This seems well! BUT!
    Now the first row and "SKALA 1:5" should only be visible. This works good in the family editor.
    1,938
    09:01 PM
    I think we need a lot more info. A Viewport is not a family you can edit in the Family editor, so maybe you mean a Title Block?
    And it would be helpful if you have some images of what you want to do or even upload the family.
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    194
    09:01 PM
    The Viewport is a system family which you can create types of.
    The actual text or annotations that show up are part of the TAG chosen in the Edit type menu.
    So i suppose you mean that in the family editor for the tag, something you are doing is working.
    Are you working with visibility parameters? As far as i know (and have seen in peoples templates). You create a TAG family and make different types in the family editor, which you can then select in the System Family's type editor. (See attached picture).
    You control what part tag shows up with visibility parameters. This is how it is configured in our template and it works.
    April 22, 2021
    07:01 PM
    I pasted some screenshots, it seems they disappeared.
    Sorry for that! I have uploaded a few pictures now!
ID:	40386Click image for larger version.
ID:	40387Click image for larger version.
ID:	40388Click image for larger version.
ID:	40389Click image for larger version.
ID:	40390Click image for larger version.
ID:	40391Click image for larger version.
ID:	40392Click image for larger version.
    January 15, 2020
    The Netherlands
    194
    09:01 PM
    Hmmmm.
    So it looks like you are trying to control the visiblity parameters of the viewport tag with project parameters.
    I suppose this is not possible and thus does not work.
    I think you need to create a different viewport type in the project for every variation of the viewport text.
    So you make the parameters in the tag family as a type parameter and not as an instance parameter.
    Then make different types for every variation you want in the family, and then link those to the different viewport types in the project.
    April 22, 2021
    07:01 PM
    I see, thank you for the fast reply!
  1. What Revit Wants: Multiple Tab Rows in Firefox
    Last Post: May 8th, 2018, 01:45 AM
  2. Schedule with rows within rows
    By cpercer in forum Architecture and General Revit Questions
    Last Post: May 30th, 2017, 10:42 PM
  3. Scheduling Areas from multiple files. Can blank rows be added for missing areas?
    By kescr in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 12:10 AM
  4. there is extra rows with 0 value
    By Eng.N.3D.All in forum Structure - General Questions
    Last Post: November 25th, 2013, 12:38 AM
  5. Schedule rows
    By Randy_CaS in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2012, 06:05 PM
