Thread: Do not show (some) Edges
    3,550
    07:48 PM
    Any good tricks for hiding the edges of some, but no all modeled elements?
    Our Wall Cabinets have a built-in Soffit family.
    Our QA team doesn't want to see joints between the individual soffits when several Cabinets are adjacent.
    The Soffit has a (yuk) Masking Region and Symbolic Lines that can be turned on & off.
    While we were just doing stick lines in Elevation, this worked fine. But now, more & more teams want to show colored elevations, and the Masking Region hides the material of the Soffit.
    If I get rid of the Masking Region and show the actual geometry, I get a line in between adjacent soffits, which we don't want to see
    So I want to hide the edges of just the ones that are adjacent.
    The Linework tool can accomplish this, but that would mean a LOT of Lineworking
Name:	Soffit Quandry.PNG
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,634
    06:48 PM
    My method for a similar situation (casework toekick) is to have it built in to the family, and an option for "Continuous Toekick". When that is checked, the built-in toekick is turned off, but the case remains a toekick height above the floor. A separate instance of the toekick family is then placed and stretched under all the adjacent casework elements. It does take a little extra management and training, but I built the family specifically to avoid the need to manually hide the dividing lines with the linework tool (which was the standard before, and took a lot of time and continual rework). The built in toekick is used only when there are single placements of base cabinets. I haven't considered doing this for casework soffits, and probably won't because there are several options for what that looks like. Usually we have either a gypsum soffit or a sloped top, which we place manually anyways.
    July 7, 2017
    Hernando, MS
    699
    07:48 PM
    A few years ago I produced shop drawings in Revit for a cabinet manufacturer, on a large millwork-heavy project (hospital office/clinic). All the upper cabinets had a sloping top surface, which I modeled as a separate piece above the row of wall cabinets. It was easier to get it to look correct that way, than it was to try to include it in the wall cabinet family.
    Also consider how it's built, typically as a single piece along the cabinet run. They don't install a bunch of separate pieces above each cabinet unit. So model it as a separate, continuous piece, just like it will be built.
    11,694
    07:48 PM
    +1 for not having the soffit in the Cabinet.
    2,900
    05:48 PM
    Make them shared/nested generic models and join them together in the project.
  1. SHow edges
    By sotekt in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2017, 02:35 PM
  2. Show or not show gypsum board in wall types
    By tidalwave1 in forum Architecture - Family Creation
    Last Post: August 8th, 2014, 03:19 PM
    Last Post: April 15th, 2013, 11:15 AM
  4. Show slab edges in Plan View
    By mdradvies in forum Tutorials, Tips & Tricks
    Last Post: December 21st, 2012, 12:57 PM
  5. Slab Edges!!!!
    Last Post: May 25th, 2011, 11:01 PM
