Thread: Some levels not visible in elevation view.
    April 16, 2012
    Naaldwijk, The Netherlands
    166
    03:28 AM
    Hey all!
    I have this floorplan:
    Where the top and bottom walls are slightly slanted (not 90 degrees angle) to the side walls.
    You see I created 4 elevations as well, the vooraanzicht and achteraanzicht elevations are perpendicular to the bottom and top wall. Now when I view that elevation, I see only three levels!?:
    That's weird right?? When I create the elevation view 90 degrees angled on the side walls, all the levels are shown.
    I've been bumping my head over this but cannot seem to find out why this is. Instead of going with my second approach I would like to know WHY is this happening? and WHY are three levels shown and ground floor, first floor and second floor levels are not?
    I've already checked in the template if the levels are not hidden (they're not) and in reveal hidden elements mode to check if they're individually hidden, which they're neither.
    2,897
    11:28 AM
    uncrop the view and see if the 3D extents are way off, or have a look in an uncropped 3D view.
    Senior Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    507
    11:28 AM
    Are those levels locked to a Scope Box? If that Scope Box does not intersect your cut plane I don't think they will show.
    April 16, 2012
    166
    03:28 AM
    This was the issue, thanks!
  1. Creating a new detail view from an exterior elevation - Section not visible
    Last Post: December 2nd, 2019, 05:31 PM
  2. Elevation Mark Not Visible
    By NijamKareem in forum Architecture and General Revit Questions
    Last Post: April 17th, 2019, 08:38 AM
  3. roof not visible in enlarged plan view but visible in all other views 2017
    Last Post: December 13th, 2017, 09:00 PM
  4. Replies: 6
    Last Post: January 8th, 2016, 07:06 PM
  5. section not visible on all levels
    By kunster in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2014, 09:52 PM
