Thread: Is it possible to create curtain wall with arc top and make the mullions arced?
    October 20, 2011
    UAE
    169
    04:30 AM
    Exclamation Is it possible to create curtain wall with arc top and make the mullions arced?
    Hi everyone!!!
    I tried to create a huge window with arc top by curtain system but when I tried to put mullions on the grid I found out that the top arc mullions attached straight from corner to corner. Is it possible to create curtain wall with arc top and make the mullions follow the curvature of the arc?
    MY FIRST THREAD
    3,205
    04:30 PM
    It should be possible. If you are trying to create a "window" using a curtain wall then sketch one over the "hosting" wall. Make sure that the curtain wall type (Curtain Wall 1 in the stock template) is using the Automatically Embed parameter (check box). When you sketch the wall over the other wall it will cut a hole for it automatically. Select the new wall and adjust it so it's the size you want then click the Edit Profile button. You'll be able to alter the sketch of the wall to use an arc for the top instead. When you finish editing the profile you'll get a new shape that matches. Just apply curtain grids and mullions to wrap it up. It could look something like this. (left image)
    It is also possible to cut a host wall using Cut Geometry, pick the host first and then the hosted wall that should cut the host (assuming you don't like the Automatically Embed concept). It works for any wall on a wall. See the second image (on the right). Smaller 4" brick wall is cutting the larger wall to create the niche. The smaller wall(s) are also hosting the windows
Name:	CW Round Top 01.jpg
ID:	4772   Click image for larger version.
Name:	CW Round Top 03.jpg
    3,205
    04:30 PM
    It is also possible to create something like in the attached image. To make this one I created a rectangle curtain wall first. I copied it to clipboard before editing. Then I used the same Edit Profile approach to alter its shape. After finishing the first one, I used Paste Aligned - Paste to Same Place to put the original curtain wall back on top of the existing one. I select the new one and use Edit Profile again. Repeat until all the pieces are in place. I did this twice, the wall in the image is three curtain walls that share common edges.
    Last I put some curtain grids in and applied mullions. Look closely and you'll see some mullions that are not very happy with their situation. To clean this up I'd probable resort to in place modeling and delete the mullions that don't work.
Name:	CW Round Top 02.jpg
    October 20, 2011
    UAE
    169
    04:30 AM
    I don't understand "stock template" part with "Curtain Wall 1" type where can I find it? Cause I tried with Simple Curtain wall it didn't work out. There is no option of Embedding
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,582
    04:30 PM
    Quote Originally Posted by spotless View Post
    this from RAC 2012 Imperial: C:\ProgramData\Autodesk\RAC 2012\Templates\US Imperial\default.rte then Home/Wall and in the Type Properties download there will be a Curtain Wall 1. Select Curtain Wall 1 and hit the Edit Type button and check the box for Automatically Embed.
    3,205
    04:30 PM
    Sorry, I failed to notice you are in Armenia when I replied earlier.
    In the metric template you'll probaby find just Curtain Wall as one of the three types of curtain walls you can use. The feature (parameter) I'm referring to is the Automatically Embed check box that will cause the curtain wall to cut into a host wall for you (see image). All curtain wall types in the template are the "same", they have the same parameters but each has different features selected in advance. The curtain wall type is the "dumbest", nothing much selected in advance while the Storefront type is the "smartest", it has more features set in advance.
    October 20, 2011
    UAE
    169
    04:30 AM
    wow!!! it was so easy just like 1 2 3
    thank you very much, never thought that curtain wall types have difference in their properties, and I always used to avoid using Storefront one. thanks again
  1. Unparallel Curtain Wall Horizontal Mullions - Possible?
    Last Post: October 23rd, 2017, 02:16 PM
  2. Curtain System - Mullions out of line
    By R-Construction in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 10th, 2014, 06:21 PM
  3. How to make dome curtain wall in revit
    Last Post: October 26th, 2011, 09:25 PM
  4. make custom opening for curtain wall ?
    Last Post: September 26th, 2011, 03:19 PM
  5. Custom Curtain Wall Panels and Mullions:
    Last Post: June 9th, 2011, 04:26 PM
