Thread: Missing Hatch patterns in AutoCAD
    June 21, 2012
    Nantes, France
    1,131
    04:20 PM
    Question Missing Hatch patterns in AutoCAD
    Hi everyone,
    I'm having an issue when exporting my Revit drawings to AutoCAD LT 2019, Please see images!
    I'm able to see all my hatch patterns in Revit but once exported to AutoCAD their are lost, I've re revisited my export settings but I've found nothing weird, If I try to export by using the Revit "By default" settings I'm having the hatch patterns but with those horrible colors, maybe I'm missing something?, thank in advance
ID:	40423Click image for larger version.
Name:	Section 1 no patterns.jpg
    April 22, 2011
    513
    02:20 PM
    -1 Not allowed! Not allowed!
    Autodesk AutoCAD and Autodesk Revit don't work together that well. I think you need to fix the dwg after the export. Love to hear how it can be improved otherwise.
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    311
    02:20 PM
    hi Andres
    and what about the others hatches on you file? is that correct or not hatch are on the DWG?
    hav you tried to to create a simple wall on this file (that you can se on the section) to see if this is the same problem than on wall with several layers?
    Phil
  1. create/ convert hatch patterns (.pat) to revit fill patterns
    Last Post: July 24th, 2015, 01:26 AM
  2. Linked AutoCAD hatch patterns not showing up in Revit prints...
    By kcaparella in forum Architecture and General Revit Questions
    Last Post: January 18th, 2013, 07:54 PM
  3. Wall Hatch Patterns
    Last Post: February 10th, 2012, 12:22 AM
  4. Some hatch patterns
    By JTB in forum Out There
    Last Post: July 10th, 2011, 11:21 AM
  5. Import hatch patterns from autocad. Export patterns from drafting to model.
    Last Post: June 15th, 2011, 09:56 PM
