Thread: Cant remove wall opening, unsure how it was created
    December 11, 2019
    36
    08:12 PM
    These wall openings are not the general "wall opening" tool that creates a stretchable space, its also not part of an edited profile. It's not from anything being hidden, and not editable when I "select pinned elements". I'm at a loss, I'm not very experienced in revit so it may be something simple I am just not aware of.
Name:	wall plan hidden reveal.PNG
Name:	wall profile.png
ID:	40447 This shows the wall in the profile editor
    3,550
    07:12 PM
    Hard to tell from your image, but its possible those might be a door demolished in an earlier Phase
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,634
    06:12 PM
    Set a view to show all and cycle through your phases - I've had gaps in walls from a wall on on a later phase that crosses through it, though your openings are too large for that to be the case. Also make sure all your worksets are turned on, since its possible something accidently got caught on a closed workset. Also, make sure you are working in a view with all elements turned on and no filters turning anything off.
    Revit likes filling in holes where anything is demolished - I'd lean towards an embedded curtain wall or door that isn't visible in some way.
    Try copying the wall and see what happens too. Do the openings remain or disappear?
    If you can't find it, maybe you could create a copy of the model with just that wall and upload a Revit file with just it?
    December 11, 2019
    36
    08:12 PM
    Interesting, the doors were visible in the copy. I just copied and pasted the wall off to the side within the same project. No other changes. What do you think this indicates?
    11,694
    07:12 PM
    Quote Originally Posted by jbourne84 View Post
    What i said on Reddit: There are objects in the wall. They are simply hidden.
    December 11, 2019
    36
    08:12 PM
    haha I realize I have doors that are hidden for some reason, since they appeared in the copy. The question is *how* are they hidden, what way could an object be hidden in the wall in one location.. but copying it off to the side in the same view reveals the hidden object.
    I used the "reveal hidden elements" toggle at the bottom of the screen as I showed in my screen shot, this is the only way I know how to reveal hidden objects.
    11,694
    07:12 PM
    There are literally dozens of ways. When you copy the wall, it takes the wall (host) and ALL of its subobjects, and creates them as brand new images. No direct-object-hiding mechanisms carry over, unless they are intelligent data tracking methods, like Filters.
    1. Right click > hide in view
    2. On a workset thats hidden in the view
    3. On a workset that isnt currently loaded
    4. On a phase thats not visible currently in the view (as has been mentioned)
    5. It SHOULDNT be a Filter, unless a filter was set up with some insanely specific criteria that affect the existing door and not the new copy (i doubt this)
    Which of the suggestions have you tried, so far?
  1. How to create an opening in a curtain system, created by mass
    By Ifyxx in forum Architecture and General Revit Questions
    Last Post: January 10th, 2020, 10:59 AM
  2. Wrap wall sweep at wall opening on a continuous wall
    Last Post: April 27th, 2018, 09:13 PM
  3. Trying to join a wall finish to a wall with an opening. Doesnt play nice
    Last Post: January 12th, 2018, 09:01 PM
  4. Why are all my walls changing to my newly created wall?
    By vicky0188 in forum Structure - General Questions
    Last Post: November 23rd, 2012, 01:04 PM
  5. Curved wall opening / faced based family opening to curved wall
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: November 11th, 2011, 12:48 PM
