hi,
this not really a tip or a trick, but it's more a reminder for newbies.
When building a family, you may become upset by padlocks and constraints.
You're allowed to select an object, let the padlock show up and then right-click on the padlock.(exactly on it).
You select "show related", then the mini-browser allows you to see constrained elements.(see pictures bellow).
Hope this helps someone.
Also, try not to lock to anything that isn't a refplane. This will get screwy eventually.
you DO mean "don't lock anything to other than a reference plane" right? I create ref planes, then dims, then parameters for those dims, verify the flex, create the geometry, and lock the geometry to the ref planes and now the geometry flexes. Is this not the correct way to do this?
That is what I said isn't it? Reread my post about three times now but I'm pretty sure... Anyway: it was already late or early (funny, I see Munkholm does the same hours as me, never met a guy working so late as I do).
But yes: ONLY lock to refplanes... (or reflines for that matter)
It would be nice to see the entire name of the reference plane in the dialog box. Does anyone have a tip for that.
I am using 2010 and the dialog box does not allow me to see the entire name. For example I have an extrusion line locked to a reference plane named Heat Sync Top, when I right click on the padlock and select Show Related... it shows "Reference Planes : Reference Plane : Heat " as you can see leaving off the rest of the reference plane name.
