after Padlock's thread, here's another one, not really tricky but VERY useful.
Consider it as a reminder:
when it comes to put a number in a cell, you are allowed in Revit to put some formula:
ex: if your input should be: "3.50" , try "=78.50-75.00". the result will be calculated.
works also with * , / , + and thanks to Mr Alfredo, pi().
don't forget it!
PS: works also with dimensions.
I use this when I am making bolts and stuff. where my paramets are half the full size... I put in 2.6875"/2 =1.34375"
dont have to do the math then.
.. speaking of that, I'd like to share that after that thread in Augi about pi some months ago, the news spread in some blogs over the internet, such as in these: (including one in French):
http://www.andekan.com/blog/2010/10/...nd-eat-it-too/
http://autodesk-revit.blogspot.com/2...1_archive.html
http://revitez.blogspot.com/2010/10/...rencontre.html
Okay, I'm a noob and don't understand. If you need 3.5 why not just type 3.5. What does making it a formula give you?
Dzatto, just faster to play with only one keyboard at a time.
Also, rounding numbers could be a problem sometimes.
