Thread: aligning colum with grid
    April 25, 2011
    Egypt
    752
    06:38 PM
    Hi , i know therea way to make concrete column snapping to grid edge showing automatci purple snapping
    by making the refrence plane is stong i did that edit family then make refrence plane is strong but it is not work any idea why
    April 21, 2011
    Oklahoma
    776
    12:38 PM
    Just clarifying, you are looking to make the column snap to grids when you hover over them with a column, yes?
    April 25, 2011
    Egypt
    752
    06:38 PM
    Quote Originally Posted by revittotd View Post
    Yes exactly
    Kingdom of Denmark
    4,262
    07:38 PM
    Any OOTB structural column will automatically snap with their centers to the grids... Are you trying to snap to something else but the center of the column?
    April 25, 2011
    Egypt
    752
    06:38 PM
    no not the center i mean what about edge of column on grid i know this is not used in construction but just try to see effect of strong refrence plane.
    Kingdom of Denmark
    4,262
    07:38 PM
    OK then, open the column family, and instead of using a "Strong Reference", change the ref. plane at the sides you want to Snap to be "Center Front/Back (Or Left/Right)"
    With columns, it's the "Center" Ref. Plane, and not the "Defines Origin" that defines the snapping point.
    July 4, 2017
    12:38 PM
    Is there no other way to achieve this than revising the family?
    Member Iberkim's Avatar
    June 24, 2016
    Denmark
    82
    08:38 PM
    Not OOTB afaik. But it shouldn't be that hard to change the the references in the family? Unless you have a badly structured family ofcourse
  1. Grid Markers in Section - Aligning with Other Sections
    Last Post: November 30th, 2011, 09:24 AM
  2. Aligning material images
    By Nathaniel101789 in forum Architecture and General Revit Questions
    Last Post: October 26th, 2011, 09:52 AM
  3. aligning bottle trap family
    By Fekoloid in forum MEP - Family Creation
    Last Post: October 20th, 2011, 06:17 PM
  4. Aligning separate drawings to the same coordinates
    By trigger in forum Architecture and General Revit Questions
    Last Post: August 23rd, 2011, 08:47 PM
  5. Aligning radius
    By Randy_CaS in forum Architecture - Family Creation
    Last Post: June 10th, 2011, 01:23 PM
