Thread: Type Catalog Visability Parameter
    Member Gabriel Black's Avatar
    April 6, 2011
    Belgium
    203
    04:57 PM
    Is there a way to control a yes/no parameter with a Type Catalog? What syntax would I use to control it?
    I've been trying the following options:
    ,Show 1 Fan##other##
    VAC1121-400,yes
    VAC1121-400,on
    VAC1121-400,off
    just to try and get a handle on it but it's not working.
    Help please?
    April 6, 2011
    Belgium
    203
    04:57 PM
    Doh! Got it. It's a tick and maths talk for yes or no is 1 or 0.
    It goes like this:
    VAC1121-400,1 (for show it) or VAC1211-400,0 (for don't show it)
    Ciao for now.
    United States
    1,155
    07:57 AM
    I find that using 1 and 0 working for this to be odd. I was trying to put a toggle in a family that is forced on and does not have the ability to uncheck and when I put 0 or 1 in the formula column it did not like it.
    I ended up using text and forcing the text to a particular thing, but I really would have thought I could do that with the Yes/no as well. Any ideas?
    3,231
    09:57 AM
    If you want to set the value of a Yes/No parameter in a family with a formula, you need to type something that evaluates to True or False. Just a 1 or a 0 does not evaluate as true or false. Type something such as 1 > 0, or 0 < 1, or the name of another Yes/No parameter.
  1. Creating Type Catalog's
    By NLG in forum Architecture - Family Creation
    Last Post: October 5th, 2011, 02:21 PM
  2. Revit OpEd: Dept. of Echo - Type Catalog Formatting
    Last Post: August 27th, 2011, 06:42 PM
  3. Area Type parameter
    By gaby424 in forum Architecture - Family Creation
    Last Post: May 8th, 2011, 12:46 PM
  4. Parameter that works as a Type, not as an Instance
    By Stuntmonkee in forum Architecture - Family Creation
    Last Post: March 16th, 2011, 03:59 PM
  5. Type parameter in a titleblock field
    Last Post: January 7th, 2011, 08:19 PM
