Thread: Scaling between projects
    January 28, 2012
    04:06 AM
    I've probably been looking right the answer to this and just don't know, but I'm new to this program so please be gentle.
    I have a family- just plain furniture- that someone else made for me that I've loaded into a project, but the scaling of it all is very messed up. [The entertainment center ending up fourteen feet tall, the sofa ending up two feet tall...] Please tell me there is a way to fix this and make everything even? Without these families being the correct size, the entire project is thrown off.
    Moderator mark b's Avatar
    NSW Australia
    1,434
    08:06 PM
    can you post the family here so we can have a look and try to help.
    January 28, 2012
    04:06 AM
    Within the project [I'll use the sofa for this question, but the problem is actually multiple families placed into the project]
    Screencap of family itself
    Noting also that the scales are different, but even when I change this within the family, the measurements don't change.
    If you need anything else, let me know. I can even link to where I got the sofa family above.
    January 28, 2012
    04:06 AM
    EDIT: I saw another thread like this just now, so attached is the file used.
    NSW Australia
    1,434
    08:06 PM
    Quote Originally Posted by Raiju View Post
    Just had a quick look at your posted lounge family and it is very poorly made. The Height, Width and Depth parameters are not referenced to anything in the model, so yes when you change these parameters in the properties nothing will change.
    The lounge family seems to be about the correct size though.
    As you haven't posted the entertainment unit family I can't comment on that, and I would have to assume that it is made the incorrect size.
  1. Scaling up walls
    By k2b4e24 in forum Architecture and General Revit Questions
    Last Post: October 29th, 2011, 10:45 PM
  2. Independent Scaling for objects on sheets?
    By billiam in forum Architecture and General Revit Questions
    Last Post: October 21st, 2011, 07:19 PM
  3. Scaling in Revit?
    Last Post: August 18th, 2011, 10:50 AM
  4. Scaling an imported Family Object
    By sebouh in forum Architecture - Family Creation
    Last Post: April 7th, 2011, 09:17 PM
  5. Raster Image Scaling
    By Darken Rahl in forum Architecture and General Revit Questions
    Last Post: March 30th, 2011, 08:33 PM
