Thread: Design Options
    6,309
    03:57 PM
    Design Options
    In typical fashion I didn't plan ahead (or didn't know I would need DO's). Is there a way I can move items from the Primary set into a DO and/or copy from one DO to another? I need to be able to adjust some stair / elevator cores and really don't want to have to rebuild the stairs three times.
    edit - copy / paste aligned works.
    -5 cool points for me...
    "OMG I killed Revit"
    dzatto's Avatar
    5,236
    02:57 PM
    Ugh, I was about to tell you that. Good job figuring it out yourself.
    6,309
    03:57 PM
    Now I do have a question - I need to be able to print both options for the client but when I select the DO it applies it across the model. Is it possible to have a view for each DO?
    dzatto's Avatar
    5,236
    02:57 PM
    You are doing the exact same thing I was. The DO box at the bottom of the screen is only for setting them up and editing. DO's are view specific. Go into the VG for the view, and there should be a DO tab at the end now. Go in there and select the one you want. Just create a view for each of them.
    I just learned about them Friday.
  1. Design Options + Materials
    Last Post: October 12th, 2011, 10:08 AM
  2. Parts and Design Options
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: September 19th, 2011, 11:14 PM
  3. Demolition and Design Options
    Last Post: May 24th, 2011, 05:58 PM
  4. Design Options
    Last Post: May 4th, 2011, 02:24 PM
  5. Design options and constraints
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 12:33 PM
