Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 74
Thread: BIM Model to Subcontractors
    Junior Member Nate L.'s Avatar
    February 10, 2011
    La Crosse, WI
    18
    01:45 AM
    All,
    I work for a Design Build Firm and we are starting to get subcontractors asking for our Revit models for there take off's. I am very reluctant to give them a copy of our actual Revit Model, however would like to give them something as that is the whole point of BIM. We had them sign a Electronic Document Release form and now I need to figure out what type of file format to give them. Any suggestions out there?
    Thanks!
    11,164
    02:45 AM
    Give them the Revit Model.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    11:45 PM
    I agree....give them the model....if you had something written up when you provided DWG files it should still apply for the Revit model...
    Now if you cheated Revit...then...well...
    6,387
    03:45 AM
    The AIA has some documents related to BIM usage. If you haven't already it is probably worth looking through.
    07:45 AM
    Stop worrying, issue a model using eTransmit and be done with it. What's the problem?
    February 10, 2011
    La Crosse, WI
    18
    01:45 AM
    Thanks all. I was more worried about giving away the client specfic content than anything however our contracts take care of that. Does anyone strip anytingout of the model or just give them the whole works? ie titleblocks our custom content that is loaded in content ect?
    Las Vegas, NV
    4,864
    11:45 PM
    Electronic stamps and signatures.....purge.. done..
    February 10, 2011
    La Crosse, WI
    18
    01:45 AM
    Perfect Thanks. Another one for you experts we are testing out giving a model and a large flat screen onsite to out superintendents so they can use the model to their advantage. We have been testing with a .dwf as we like the markup tools that come right into Revit for communication. Does anyone else use this process or have a better one? The only problem that I have run into is that the .dwf file opens very slow and will crash when cutting too many sections.
    Thanks!
    Las Vegas, NV
    4,864
    11:45 PM
    There was a course at AU 2011 about this....where they had a job box with a big screen and the Revit model....superintendents could save pdf's of what the needed to see and transfer it to their iPad's....
    I think it was Aaron's class...
    February 10, 2011
    La Crosse, WI
    18
    01:45 AM
    I'll try & look up the class and see what I can find. Thank you. mmmmm a tablet...I really want one of those...
    Last Post: November 22nd, 2011, 11:45 PM
  2. Structure model vs arch model - cutting
    Last Post: November 13th, 2011, 02:03 AM
  3. Zoned model files > Single Model file
    By n8wex in forum MEP - General
    Last Post: August 15th, 2011, 05:16 PM
  4. Printing host model with linked model
    By IMCarter in forum Structure - General Questions
    Last Post: May 11th, 2011, 01:00 AM
  5. Model Entry Gate Far Away From Main Model
    Last Post: April 26th, 2011, 05:29 PM
