Thread: Column Base Plates
    November 28, 2011
    Ontario, Canada
    154
    01:46 PM
    Column Base Plates
    Hello All
    I am trying to create a column base plate using the extensions addon, I have a hss column on a pier, when I select the column and then steel connections under the extensions pull down, then I selected column base.
    I recieve the following error, I don't seem to have a problem when selecting an w column
    "The column section is incorrect"
    Can someone tell me why this would happen?
    I tried to add a base plate using the component method but i couldn't seem to get the plate to go to the bottom of the column.
    thanks in advance
    Alex Cunningham's Avatar
    Northern California
    3,575
    09:46 AM
    You say you are using an addon... What addon? Have you talked with the developer of the addon
    Is the pier a column or a foundation family?
    Are the pier and column associated to eachother?
    November 28, 2011
    Ontario, Canada
    154
    01:46 PM
    obviously the word "addon" was a poor choice of words.
    lets start again shall we.
    so i know what i need to do on my project, i started a simple project with some columns and spread footing, I want to add a base plate to an hss column. so i selected the column and went to the extensions tab, steel connections, column base, after a short bit I receive the following error message.
    Apparently it does not seem to be a problem if I use a W column
    I was able to get the add componet method after realizing that the family i downloaded was labelled incorrectly but it is not what I want to do.
    what I want to do is to create the base plate types I need and "insert or add them to a column I have" (would like to model this for a particular drawing I need to do but if revit is limited in this aspect then i will have to make the component method work for now.
    The only thing i know of for the pier was to use a concrete column, never the less, if it doesn't work on an entirely new project with a column on a footing, then either the software has its limits in this area or i am missing something.
    Moderator LeanneZ's Avatar
    Charlotte, NC
    792
    12:46 PM
    I just tried... I have the same error. Need to log the issue with Autodesk through your subscription support.
    December 12, 2010
    New York
    322
    08:46 PM
    Did you set the correct Location in Extensions options?
    ...brainstorming
    September 16, 2011
    Perth, West Australia
    138
    01:46 AM
    I've had similar experience with the 'limits' placed on Revit Extensions. As an example I can't export a footing to ASD using Revit Extensions unless it has a column attached to it. Maybe Autodesk need to relax their limits a little.
    March 21, 2011
    Brisbane
    290
    03:46 AM
    From memory the Steel Connection extentions don't work on hollow sections - only on UB's.
    Johk
  1. Base Extension and Wall Cleanup
    Last Post: August 8th, 2017, 06:51 PM
  2. Profile base point
    Last Post: February 14th, 2012, 03:07 PM
  3. Missing wall base
    Last Post: July 8th, 2011, 10:26 PM
  4. How to move Zero point of base project
    By pcamliti in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2011, 06:29 PM
  5. outlets in wall base
    By sca in forum Architecture and General Revit Questions
    Last Post: April 27th, 2011, 09:13 PM
