Results 1 to 10 of 18
Thread: Transfer Legends between projects
    Junior Member Theophilous's Avatar
    February 1, 2012
    Vancouver Wa.
    36
    09:28 AM
    Exclamation Transfer Legends between projects
    I started a new project and noticed that the template file did not have my legends...
    How can I transfer the Legends from one project to another?
    Copy/Paste - Did not work
    Insert Views from Project - No go
    Trasfer Project Standards - No go
    I did create a group of the objects in Project A (where the good legend is located) and pasted the Group in Project B
    But it looks like this!
    Any help would be greatly appreciated!
    February 17, 2011
    Raleigh, NC
    193
    11:28 AM
    In Project B, make sure the scale of the legend view is the same as the scale of the legend view in Project A.
    Alex Cunningham's Avatar
    Northern California
    3,575
    08:28 AM
    If thats a key schedule... you are out of luck.
    I copy and paste the legend into a drafting view then transfer from project to project. This method doesn't work for everything.
    February 1, 2012
    Vancouver Wa.
    36
    09:28 AM
    Quote Originally Posted by LKeyser View Post
    Thank you for the reply and help. As it turns out the scale is the same and this time I simply tried to copy and paste objecs from one... Same results...
    I can just adjust this and run with it... What is the process of transfering Legends if there is a way to do so?
    Thank you!
    February 17, 2011
    Raleigh, NC
    193
    11:28 AM
    Is the text style you're copying in from Project A named the same as a text style in Project B that is a different size? If so, it will use the settings in project B and cause the behavior you've shown.
    February 1, 2012
    Vancouver Wa.
    36
    09:28 AM
    Thanks for the reply.
    It is a Legend View.
    That was a good idea, but it did now work.
    In Project A - I created a new drafting view in order to copy and paste the content from the Legend View. The same problem happens when I paste those objects. All they are is Text and Drafting Lines...
    Not sure if you can tell in the image, but what happens is all the objects get piled up on top of each other...
    Thank you for your help
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    08:28 AM
    Try grouping it first then copy and paste....
    February 1, 2012
    Vancouver Wa.
    36
    09:28 AM
    Before the copy of the object into Project B, I did a project transfer of the Text styles first from Project A to B...
    Thanks for the idea...
    February 1, 2012
    Vancouver Wa.
    36
    09:28 AM
    Did that, but got the same result...
    Thank you for the help
    Moderator LeanneZ's Avatar
    Charlotte, NC
    789
    11:28 AM
    Quote Originally Posted by Theophilous View Post
    Thank you!
    Looking at the pictures that you posted, the scales are not the same. one is 12" = 1'-0" and the other is 1/2" = 1'-0"
    You may have made the pictures before you tried verifying the scale... could you check again? (Just so we can all learn what works and what doesn't.)
  1. Transfer Project Standards error - any ideas?
    By Darryl_S in forum Architecture and General Revit Questions
    Last Post: June 5th, 2015, 11:36 AM
  2. Transfer Project Standards broken?
    Last Post: December 16th, 2012, 07:52 PM
  3. Transfer Revisions to consultants
    Last Post: December 9th, 2011, 07:47 PM
  4. Building Coder: Transfer Project Standards
    Last Post: September 14th, 2011, 10:10 AM
  5. Hey, Problem with Revit To Robot Transfer..
    By dx69 in forum Structure - General Questions
    Last Post: August 8th, 2011, 08:19 PM
