Thread: handrail on sloped roof
    January 15, 2012
    London UK
    12:38 PM
    Hi, how could i trim the handrail ends to match the sloped roof? Is there a quick option for that? TX
    Moderator mark b's Avatar
    NSW Australia
    1,432
    11:38 PM
    Sorry no way to acheive this with railings. I know it should be simple but its not.
    There are a few work arounds;
    1. use a curtain wall , turn off glazing panel adjust grid to suit verticals then edit profile.
    or
    2. Use a beam system see here,edit profile, then add a beam for top rail
    January 15, 2012
    London UK
    12:38 PM
    Thanks a lot Mark! both options are really great.
    May 23, 2011
    Netherlands
    588
    02:38 PM
    can be done, but only with one railing direction at a time. split the railing base line and mark one section as 'sloped' and give it an offset. all railings will follow that slope, but you can always duplicate and make a non-sloped version for a straight bottom or top. balusters should begin at a level rather than a rail number to keep them aligned at the bottom (or top, for that matter).
    NSW Australia
    1,432
    11:38 PM
    Quote Originally Posted by ekkonap View Post
    yep, you are right, another workaround but at least you are using a railing. either way still bit of a workaround.
  1. Double sloped roof and matching ceiling.
    Last Post: July 30th, 2018, 09:00 PM
  2. Flat Pad on Sloped Roof
    By B Arch in forum Architecture and General Revit Questions
    Last Post: November 23rd, 2015, 10:36 PM
  3. Handrail bracket
    By Dave Jones in forum Architecture - Family Creation
    Last Post: September 7th, 2011, 12:09 AM
  4. Handrail
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: June 30th, 2011, 12:28 PM
  5. sloped roof connection between two parts
    Last Post: May 19th, 2011, 10:50 AM
