Results 1 to 8 of 8
Thread: Concrete formwork shutters
    September 16, 2011
    Perth, West Australia
    138
    05:09 AM
    Guys,
    Does anyone know if there are any Revit plugins that assist with formwork shutters?
    For insitu walls and columns we produce both a 'formwork components' drawing (a legend of all the different size formwork shutters we have) plus a layout drawing for each level showing site how to position each formwork shutter to create the desired wall/column. I have attached a couple of screenshots.
    Is there anything that can do this within Revit? My thinking was we could create new families of each shutter (size, ID etc) then if Revit (or a plugin) can automatically calculate the best way to position the shutters based on the wall/walls selected and then place them we could develop layout drawings and a materials takeoff schedule.
    Does anyone know of anything that will do this?
    Thanks.
ID:	7130Click image for larger version.
    French Moderator jbenoit44's Avatar
    Nantes, France
    1,381
    11:09 PM
    I do things like that in Revit all day long. I have families for my formworks (metal panels), and use both groups and assemblies.
    Schedules and work breakdown is also done in Revit, with a large use of filters and shared parameters.
    For automation, you will need to put some money on the table for API. But can be done for sure.
    September 16, 2011
    138
    05:09 AM
    Excellent Julien, would you mind sharing some of your processes with me please? Who do I give money to for API, I am very good at spending money to increase productivity.
    December 12, 2010
    New York
    322
    12:09 AM
    Julien is a formwork guru. Watch the first Live Revit session.
    September 16, 2011
    138
    05:09 AM
    Link pls Lucis?
    December 12, 2010
    New York
    322
    12:09 AM
    Quote Originally Posted by JasonWallis View Post
    Link pls Lucis?
    Here it is, friend:
    http://www.revitforum.org/live-sessi...enoit44-2.html
    September 16, 2011
    138
    05:09 AM
    Thank you very much.
    January 30, 2017
    02:39 AM
    can u please share formwork design procedure in revit architecture.how do panels created and assembling process.
  1. Concrete beam schedules?
    By LeanneZ in forum Structure - General Questions
    Last Post: January 26th, 2016, 01:31 AM
  2. Concrete Shearwall Elevation
    By kev4174 in forum Structure - General Questions
    Last Post: January 24th, 2012, 08:18 PM
  3. Concrete slab edges
    By stl4310 in forum Architecture and General Revit Questions
    Last Post: December 14th, 2011, 10:08 AM
  4. Concrete Cover Schedule
    By gdoherty0102 in forum Structure - General Questions
    Last Post: October 24th, 2011, 07:43 PM
  5. RST Q1: Formwork drawing
    By gaby424 in forum Structure - General Questions
    Last Post: July 16th, 2011, 11:04 AM
