Page 1 of 57 123451151 ... LastLast
Results 1 to 10 of 565
Thread: Revit Hardware : Video Graphic Cards
    United States
    1,663
    05:05 PM
    Hi all - as of 2019, I'm no longer updating these hardware threads (unless there's a major change in technology or the way Revit utilizes hardware). The details, model numbers, CPU/GPU names, etc. may be slightly different, but the concepts are still the same. Still feel free to post questions or comments in this thread.
    I've attempted to write this series of posts in a way that will be accessible to everyone. It may seem a little boring and geeky, but you'll be better prepared in making purchasing decisions, or when asking questions or for advice. Also please note that the recommendations given here for specific products are not exclusive - there are too many usage scenarios to cover every option.
    VIDEO GRAPHIC CARDS
    The "video card" is also referred to as a "graphic card" or as the "GPU" (Graphic Processing Unit).
    There are two main types of GPUs: "discrete" graphics, or "integrated" graphics. Discrete is a video card installed in a desktop or embedded in a laptop motherboard. Integrated is when the GPU is integrated into the CPU itself. Discrete graphics generally provides better performance, and y
    ou'll almost certainly want to have a computer with discrete graphics to take full advantage of all of Revit's "advanced graphic" display features.
    The GPU
    The GPU is the equivalent of a CPU on the video card - an engine that processes data from the computer to your display screen.
    There are two main GPU providers: NVIDIA and AMD (formerly ATI). They typically sell their GPU (chipsets) to other manufacturers who then package them into video cards (or embedded into laptops) that you actually buy (or are provided to computer makers like HP and Dell). It's a lot like how Intel sells CPUs but you can't actually purchase a computer from Intel.
    Nvidia has a consumer (gaming) line of video cards known as "GeForce" and a professional (workstation/CAD) line known as "Quadro".
    AMD has a consumer (gaming) line of video cards known as "Radeon" and a professional (workstation/CAD) line known as "Radeon Pro" (formerly "FirePro").
    The other major supplier of GPUs is Intel itself. Most of their new CPUs actually have a GPU integrated into the CPU (i.e. integrated graphics). Though Intel's latest integrated GPUs (iGPU) are much faster than the old days, they are still slower than what most users will need for Revit - so you want to avoid relying on these. It still is not on par with the recommended GPUs listed below, but theoretically, the latest iGPU's could do in a pinch. From what I've heard so far - it's fine with Hardware Accelleration turned off, but exhibits issues when HWA is turned on. Please share your experiences with the newer Intel graphics!
    When looking at laptop specifications, be aware that a number of laptops come with both the Intel GPU and a discrete AMD/Nvidia GPU. This offers the best of both worlds. The laptop uses the faster discrete GPU when using apps like Revit, and the integrated Intel GPU the rest of the time to save battery life.
    Video Memory (Video RAM)
    2 GB video RAM is the minimum recommended for typical usage, though this has less to do with Revit specifically, and more to do with the OS/software requirements in general. Almost all new video cards (including those in laptops) come with 2 GB of video memory, which should be plenty for Revit.
    If you have an older video card with 1GB or less, that's often still enough to run Revit, though it may result in performance problems or even crashing on more recent versions of Windows.
    One of the reasons Intel's integrated graphics are slower is because they don't have large amounts of dedicated video memory of their own - they share the system RAM. Even if you have lots of system RAM, this way of sharing memory is much slower than dedicated video memory.
    More video memory will not make Revit run faster. Also, don't concern yourself with the different speeds of video memory (unless that's part of recommendation of a specific video card) - just focus on getting the best card within your budget, and the tech jargon will take care of itself.
    Drivers
    Video card drivers are necessary for the operating system to work with the video card. Finding a driver version that will work flawlessly with Revit isn't always easy. If you do find one that works really well, you'll probably want to stick with it until it doesn't (new versions of Revit can bring you back to square one). This is one area where always having the latest updated driver isn't necessarily a good thing... new drivers may perform worse than older drivers. If you're working with two different versions of Revit, sometimes it can be a frustrating situation where one driver version works better with one version of Revit, while another driver version works better with a different version of Revit. In that case, you'll just have to make a choice.
    Video card drivers are generally provided in three ways: by the manufacturer of the chipset (i.e. Nvidia, AMD or Intel), or by the manufacturer of the video card (e.g. Asus, EVGA, etc.) or by the manufacturer of the computer (e.g. Dell, HP, etc.). For most users, it's best to start with whoever made the chipset, i.e. Nvidia, AMD or Intel. Nvidia and AMD update their drivers every few months... and computer and video card manufacturers often stop updating their versions of the drivers after a year or two. With desktops, you can use whatever supplier you want. However, laptop video cards may require a driver provided by the manufacturer of the laptop - in that case, you may not have much of a choice.
    After installing a new or updated driver, it's a good idea to actually power OFF your computer (and it doesn't hurt to give it a few seconds before turning it back on) - using the Windows "Restart" button occasionally does not clear the old driver for whatever reason (while this may not be necessary for every brand and model of video card and driver version, it's better to be safe than unsure whether the driver you just installed is actually working as intended).
    Links to drivers on Nvidia/AMD (ATI) websites (USA):
    Nvidia Reference Drivers
    AMD Reference Drivers
    GPU Rendering
    Revit does not use the video card to process renderings. It's entirely based on the CPU (and available system RAM). However, there are a number of third party apps that can make use of the video card when rendering. GPU rendering uses the GPU on the video card to process the rendering... and because the GPU is so specialized at what it does, it can process realistic renderings much faster than the CPU can. While it's beyond the scope of this post to thoroughly examine GPU rendering via third-party software (iray, Octane, Indigo, etc.), the basics are: many GPU renderers use a method involving "CUDA" which is currently only supported on Nvidia video cards. Also, GPU rendering needs lots of fast video memory. So, if you want to do GPU renderings, you'll want the fastest Nvidia card with largest video memory you can afford... and two video cards can be even better than one (they don't necessarily need to be identical or in an "SLI configuration").
    Currently there's no super easy way to get your Revit model into third-party software in order to take advantage of GPU rendering. It requires exporting the model into other software, and a bit of extra setup before you can actually create a rendering. The vast majority of users will not bother with the extra work and software involved. If it is something you're interested in, don't hesitate to start or add to a thread on the subject.
    Benchmarks
    Just like CPUs, you can compare the performance of video cards through benchmark testing. Most benchmarks focus on video games, and Revit is not a video game (as much fun as that might be), so don't take benchmarks too literally as they apply to Revit. Performance differences may be more subtle. However, they do provide a guide as to where a video card is in the performance pecking-order.
    Tom's Hardware Benchmarks
    Note that the GPU benchmarks included in the current RFO Benchmark cannot be used for direct video card comparisons - the results are significantly affected by the CPU.
    4K/5K & HiDPI & Retina Displays
    4K displays (
    3840 x 2160 pixels) and HiDPI/Retina displays have become increasingly popular over the last couple of years. However, these high resolution displays come with all the caveats of a new technology, and you should do your research before purchasing one.
    HiDPI (or HDPI, i.e. High Dots Per Inch) and Apple "Retina" displays refers to very high density pixel displays. An
    HiDPI display is generally any display with double the resolution (in both directions) of a similarly sized standard resolution display.
    The purpose of such displays is not necessarily to increase the screen real estate (though in a sense they can be used in that way), but rather to make everything on the screen extra sharp by scaling up screen elements to a normal size using twice the number of pixels in each direction (i.e. 4x the number of pixels). For example, a 3840 x 2160 resolution would show the same sized screen elements as a 1920 x 1080 screen, but those elements would appear twice as sharp because they're using four times the number of pixels.
    However, and this is a very significant caveat, Windows and the applications that run on it, weren't originally designed to use HiDPI screens. The way Microsoft addresses this is through Windows Display DPI scaling. Windows can "scale" the size of elements on screen to be more readable (this isn't a literal "scaling" like in Photoshop, but we're not going to dive into the technical details here). Windows has had some form of DPI scaling since Windows XP, though the results have always been rather mixed. Microsoft has continued to refine the way DPI scaling works, and with the latest changes in W10, and the increasing popularity of HiDPI displays, developers are finally beginning to take notice. However, presently a lot of software still does not work very well when a very high DPI scaling is used.
    Users new to a HDPI display will usually find one of two things when they boot up their new computer: either no DPI scaling is used and everything looks so tiny on their screen that it's almost unusable, or everything looks normal, but some applications behave oddly (that used to include Revit until very recently, but Revit 2017 and the latest updates to 2016 and 2015 should work pretty well).
    The solution is to dive into the Windows Display DPI scaling settings. Since each version of Windows handles this a little differently, you may have to do a little googling, but there are tons of support articles. In Windows 8.1/10 (which is strongly recommended for any system using a 4K or HiDPI display), you can find the settings in Control Panel > Display. You'll see a "Change the size of all items" slider from Smaller to Larger. Depending on the resolution of the display(s), there will be between one and four settings, starting at 100% (Smaller), 125%, 150%, 200% (Larger). 200% is the ideal setting for most HiDPI displays, but if you're having trouble with any applications at that setting, or simply like a little more screen real estate, 150% is generally a good c
    ompromise between a high DPI scale factor and comfortably sized screen elements.
    Here's a very thorough and somewhat technical article
    Scaling Windows - The DPI Arms Race (Anandtech) on the state of affairs.
    The other important factor to keep in mind is that on displays with 4K or more, that's a lot of pixels to push around - you'll want a high-end GPU to go along with it.
    FAQ
    “Autodesk/my reseller/unnamed CAD expert says I should only use "Professional" (workstation/CAD) cards with Revit. But then I read here that lots of people use and recommend "Gaming" cards for Revit. Who is right?"
    Despite what you may have been told, consumer (gaming) video cards can work just as well with Revit as professional video cards.
    "Come on, there's got to be more to it than that! Those "Pro" cards cost way more - they must be better in some way?"
    Yes, there is more to it than that, though "better" is open to interpretation. Officially, Autodesk only "supports" professional video cards. In very simplistic terms, what that means is that Nvidia/AMD "validate" specific drivers (for their Pro cards) to work with specific versions of Revit (and other specific CAD apps). If you're using a supported card with a validated driver with the version of Revit that it's been validated for, you can be very confident that you're not going to have compatibility problems. You are paying for that assurance. Furthermore, you have some assurance (but no guarantee) that the next few versions of Revit will likely also be compatible with your Pro video card.
    "That's it? You're telling me that the $250 "Gaming" video card has the same performance as the $750 "Pro" video card?"
    Yep.
    "But what about other CAD software like AutoCAD, 3ds Max, SketchUp, etc.?"
    I can't speak for every CAD app out there, but generally speaking, the same goes for any software that can use DirectX for graphic hardware acceleration.
    "I'm still having a tough time making a decision which way to go... Any final thoughts on this?"
    Well, let's be clear - I'm not trying to talk you into anything. There is no "right" or "wrong" here. If you've got the budget, there's not much to be lost by getting a "Pro" card. It's just that what many users with experience in this area have found is that there's not much to be gained either. Personally (and many have shared the same experience), I've had just as many issues with "Pro" cards as I've had with "Gaming" cards. It's not uncommon for a new version of Revit to be released, and suddenly the video card that worked great with the previous version doesn't work so great with the new version. No matter what card you're getting, your best bet is to get a video card that other users have had success with.
    “I do a lot of rendering. What's the best video card for rendering in Revit?”
    By far, the most common misconception is that the video card processes renderings in Revit. While completely understandable, it’s simply not the way it works… at least in regards to Revit. Rendering performance in Revit relies solely on the CPU (and available system RAM).
    "I noticed you qualified that last answer to Revit. What if I do a lot of rendering in 3ds Max or other rendering apps?"
    See the "GPU Rendering" section above.
    "Are you sure there's no GPU rendering in Revit? Maybe you haven't seen the new "ray tracing" visual graphic style in Revit?"
    Yeah, I'm sure (as of Revit 2017). The new "ray tracing" in Revit does not use the GPU - it's still relies entirely on the speed of the CPU.
    “Does Revit need a fast video card? How fast?"
    In the old days of Revit, a super fast video card wasn't particularly useful. These days, the answer is somewhere in the middle. Getting a $500+ "Gaming" card (along with SLI/CrossFire) or a $1,500 "Pro" card is often waste of money - money much better spent on a faster CPU. Despite all the 3D graphics, Revit doesn't require the resources of the latest video games. However, recent versions of Revit appear to offer increased general use graphic performance improvements with a decent GPU. Another factor is how many displays your running Revit on and what kind of resolution they have. The more pixels on the display, the more work the GPU has to do (this is especially true of HiDPI/4K+ displays). Unfortunately, it's kind of hard to know exactly where the line is in diminishing returns. We're mostly relying on users first-hand experiences. Recommendations are given at the end of this post.
    “But what about spinning around the model and changing views?”
    In the past, this was mostly relying on the CPU to generate the actual geometry, but recent versions of Revit appear to benefit greatly from a fast GPU. Again, how much so is very subjective. If you use a lot of graphic options like Shadows and Realistic View, a fast video card can make a HUGE difference in processing those parts of the view compared to a slower one.
    "Someone told me that SLI or CrossFire will double the speed!"
    SLI and CrossFire may work great for the latest video games, but it's of no use at all for Revit - at least it's never been demonstrated. If you want to give it a try, let us know how that works out for you. ;-)
    "I know you said 2 GB of video RAM is enough, but I'd feel better if I had 4 GB card."
    Okay. But frankly, it's more of a marketing thing than an actual need. Revit really doesn't need very much video memory. 2 GB should be plenty for the next few years. Graphic options such as Shadows really don't use up very much memory, and you would have to have an insane amount of "materials" in Realistic View to push the memory constraints. You can have literally dozens and dozens of windows open and not use up 2 GB of video memory. Keep in mind that there's a huge difference between Revit and a video game like GTA V.
    Note that some GPU utilities have shown Revit to use all the available video memory, even on very small projects - however, there isn't any evidence that Revit is actually "running out" of video memory, or that it actually affects performance.
    "Will more video memory make the video card go faster?"
    This was already addressed above, but it bears repeating because I see this misconception all the time - the amount of video memory has almost nothing to do with the speed of the video card in regards to Revit (or even video games for that matter). To make a car analogy: the amount of memory on the video card doesn't affect the speed of the video card anymore than the amount of fuel in your car affects the top speed of your car.
    "How do large resolution displays and/or multiple displays affect graphic performance?"
    Technically, benchmarks show that the lower the resolution, the faster the benchmark. This is actually observable by resizing the Revit application window to be small (or changing your display resolution to be very low). However, what has not been demonstrated is whether a faster video card will relatively improve overall system performance.
    "So, if I want the fastest graphic performance, I should get the fastest GPU?"
    Well, not quite. There are diminishing returns. Graphic performance does improve with faster GPUs up to a point, but then perceivable improvements in performance level off. This leveling off in performance is reflected in the GPU recommendations below.
    Choosing A Video Card
    According to Autodesk, the minimum requirements for a video card for Revit 2015 is any display adapter capable of 24-bit color (i.e. any video card), however if you want to use Revit's advanced graphics features, you'll need a DirectX 11 capable graphics card with Shader Model 3. Any GPU of the last few years has DirectX 11, and any GPU since ~2006 has Shader Model 3. So the bottom line is if you're purchasing a new computer/GPU, any new computer will meet the requirements.
    Both Nvidia and ATI cards can work great, so this should be easy, right? If only it were that easy. There are a number of issues that need to be considered.
    First, and this is to put it diplomatically, Revit has a checkered past with video card compatibility (though it's gotten a lot better in the last couple years). Unlike all other computer hardware, Revit sometimes has trouble with certain brands or models of video cards. Revit might crash, or weird "graphic artifacts" may randomly appear on the screen, or the Ribbon might start acting funny. Sometimes it’s just a matter of updating the video card driver, and sometimes it means you need a different video card.
    Also, unlike a CPU where increasing performance is very linear, graphic performance in Revit can be rather subjective, where differences in performance can sometimes be a fraction of a second, and sometimes spending twice as much on a video card doesn't buy you any more performance... so read on...
    Autodesk Revit Graphic Hardware Support Site
    For starters, you may want to check out the official Autodesk Revit Graphic Hardware support site:
    You'll find links to the official "Graphics Hardware List" and a FAQ.
    Unfortunately, Autodesk only lists support for "pro" cards, so all of the most widely available "consumer/gaming" GPUs aren’t listed. Also, there list is often not current, especially for AMD GPUs. However, if you want to stick with a GPU supported by Autodesk, that's the place to start.
    Brands
    There are many brands of video cards that incorporate Nvidia and ATI chips onto the video cards. If you buy a retail computer, such as an HP, you’re going to get whatever they give you, likely with an HP sticker on it (they just contract out the card from another manufacturer). So, is there a difference between brands? For the most part, you get what you pay for. If you're buying a video card as an add-in (e.g. from amazon.com or similar), read the reviews, do a little research. A number of users have had consistently good experiences with these top tier brands:
    Asus
    EVGA
    Gigabyte
    MSI
    PNY
    Many others probably work fine – I’d be particularly interested to know brands that users have had good or bad experiences with (though, keep in mind that even the best brands have failures).
    When shopping for a new computer or video card, consider the following video cards... Note that these are only suggested as minimum starting points - in actual usage, you might not notice any difference between a GTX 850M that's on this list and a GT 840M that just missed the cut:
    Desktop
    AMD Radeon: R7 350X (non-OEM) or better.
    AMD FirePro: W4100 or better /
    Radeon Pro WX 4100 or better
    Nvidia GeForce: GTX 9xx or better, GTX 10xx or better (essentially any newish GTX).
    Nvidia Quadro: K2000 or better, K2200 or better.
    Laptop
    AMD Radeon: R7 M460 or better.
    AMD FirePro: M5100 or better.
    Nvidia GeForce: GTX 10xxx or better, GTX 9xxM or better.
    Nvidia Quadro: M1000M or better.
    Note: For GeForce cards, the first number, e.g. 7xx, denotes the "series" (higher numbers are more recent), but it does not denote performance. It's the second number onward that indicates performance level. For example, the GTX 950 is SLOWER than the GTX 780 (though how perceivable that is in Revit, and under what conditions, is subjective/untested). If you're unsure, do a little research or post a question.
    Note: For Radeon cards, GPU's are denoted first with a performance series number, R5, R7, R9, followed by a three digit performance number. Also, it appears the "FirePro" has been superseded by the "Radeon Pro". If you're unsure, do a little research or post a question.
    To be avoided outright:
    Nvidia Quadro NVS.
    Intel integrated graphics (caveat described in a previous section above).
    Bottom Line
    There are lots of video cards that will perform just fine with Revit, but here are what should be some safe bets without spending more than you really need to:
    Desktop
    Nvidia GeForce GTX 1060 / GTX 960
    Nvidia Quadro K2000 / K2200
    Laptop
    Nvidia GeForce GTX 850M / GTX 860M / GTX 1060 (Notebook)
    Nvidia Quadro M1000M / M2000M / M3000M
    Note: I have not personally tested all of the listed GPUs in this article nor can I give assurances to compatibility with Revit - they are recommended based on shared user experience, specifications, and educated guesswork.
    Additional Resources (Wikipedia)
    Comparison of Nividia GPUs
    Comparison of AMD (ATI) GPUs
    __________
    I've been a computer enthusiast for over twenty years. I know a lot, but I don't know everything. Drop me a PM with suggestions, or if you spot any errors, or think something needs further clarification, or feel free to take it up with me in the forums. And please *post* those questions, requests for advice, and solutions!
    United States
    1,663
    05:05 PM
    This thread is primarily a place for users to contribute recommendations and first-hand experiences related to graphics/video cards, discuss new graphics cards, and troubleshoot graphics card issues.
    It is recommended that you start a new thread (or piggyback on to an existing one if appropriate) if you need general hardware troubleshooting help, or have broader hardware questions or recommendations.
    A few points to keep in mind when discussing graphics cards:
    Nomenclature: Graphics card, video card, GPU (Graphics Processing Unit) - they all refer to the same thing. Discrete graphics usually refers to a stand-alone video card or a separate GPU on the motherboard (as often found in a laptop). Integrated graphics usually refers to Intel graphics integrated into the CPU.
    Hardware Acceleration (HWA for short). When using certain views or graphic effect (shadows, Ambient Shadows, Realistic View, and Anti-Aliasing), Revit can take advantage of graphics hardware acceleration built into the GPU. There are two options in the Revit Options (Revit Options > Graphics tab) - one to enable Hardware Acceleration and the other to enable Anti-Aliasing (which makes line work display with less jagged edges). However, the reason these are "options" is that sometimes Revit doesn't play friendly with the graphics card. The HWA is the most common cause not only for obvious graphics glitches, but also issues with the Ribbon and crashes. Often, the very first thing to try when troubleshooting issues with Revit is to turn off HWA (and Anti-Aliasing).
    Important Info to include when discussing GPUs:
    Is Hardware Acceleration enabled? Does HWA work without issues?
    Include as much information as you can or is relevant to the discussion:
    GPU: e.g. GeForce GTX 660Ti, Quadro K2000m
    Video RAM: 512MB, 1GB, etc.
    Brand model of video card: e.g. MSI N460GTX Cyclone, Dell/OEM (i.e. came pre-installed on a Dell), etc.
    Driver version (Reference driver downloaded from Nvidia/AMD site, or OEM driver from Dell, Asus, etc.): e.g. Reference driver 197.03, Asus driver 259.22, etc. It's particularly important to include this if the video card doesn't work well, since often installing the correct driver (particularly on newer cards) will fix the problem.
    Windows version: XP, Vista, 7 / 32-bit or 64-bit
    Version(s) of Revit: e.g. RAC 2013, RST 2013, MEP 2013
    Please make note that the video cards discussed in this thread are based on users' individual experiences, and no one shall be held responsible if the information is incorrect, out of date, the video card doesn't work as expected, etc. There are no guarantees - follow recommendations at your own risk.
    United States
    1,663
    05:05 PM
    I'll get the ball rolling here:
    I'm very pleased with the GeForce GTX 460.
    I purchased it a few weeks ago to replace an older existing video card that wasn't working so well. So far, the GTX 460 has been working great. Most of our projects are currently under 100MB. Turning shadows on is pretty close to instant to a second or two at most.
    There is a minor bug where the Revit status bar occasionally "dances around" or "loops" (you'd know it if you saw it) for about ten seconds, at which point you just have to wait for it to finish looping. It randomly happens once or twice a day, but it's so minor that I don't consider it a reason not to recommend the card.
    Nvidia GeForce GTX460 (1GB)
    MSI N460GTX Cyclone
    Windows 7 64-bit (most recent reference driver)
    Revit RAC 2011
    30
    08:05 PM
    I've seen that same looping dance on my machine and I've found that simply opening the task manager stops it in its tracks. No end task or process just open the TM and it stops jumping around. It was due to a system resource widget that I have running that I noticed processors spiking when the status bar started dancing and just want to find out what was up. Still haven't figured out why it starts doing it but I know how to stop it.
    United States
    1,663
    05:05 PM
    Good to know! I'll try that next time. In my experience, it's infrequent enough and short enough that I don't know I'd even bother. But if it ever goes on and on, I'd feel better knowing there was some way to stop it and save my work.
    BTW, any unlisted video cards you want to share with us to add to the list?
    30
    08:05 PM
    Yeah, its deffinitely not a major problem but I just get a little impatient sometimes. I'm running a GeForce GTX 275 with the 8.16.11.9107 drivers. Its treated me well even though its not on the list. Also I haven't checked for newer drivers.
    Rotterdam, South Holland
    3,071
    01:05 AM
    On the nVidia driver front...
    We are using GTX 460 & GTX 470s for most of the staff, and I have the GTS 250 we did initial testing on. We had been 100% trouble free until recently, when we upgraded to the (most recent) 260.99 drivers. At that point, a number of problems with screens going blank and lines disappearing started to crop up. I and another user are now on the 258.96 drivers, with no troubles at all. If all goes well I will revert the entire office to 258.96 and report back.
    FYI, you will notice that there are two formats to refer to nVidia drivers. When you go to download the driver package you will see the ###.## format, while if you look at the driver version in Device Manager you will see the #.##.##.#### format. The key is that the last five digits of the latter format will match the former. So
    The 258.96 download installs the 8.17.12.5896 driver version. And the download to get Eric's driver is 191.07. Why nVidia does this is as unknowable as why Carl loves the ribbons.
    Gordon
    Austin, Texas
    290
    07:05 PM
    Gordon, I started downloading 260.99 right before you posted this. I may still install just to see if it does weird things here
    3,071
    01:05 AM
    Rick, just download 258.96 at the same time. I am curious to see if your results match ours. Note that the 260.99 drivers work fine for most users here. But we have a few people who are seeing issues. But the one who is hammer in 3D the most (ambient shadows on at all times, very complex views, etc) was seeing blank screens a couple times a day, and has seen no anomalies in the last 24 hours. FWIW.
    Gordon
    Austin, Texas
    290
    07:05 PM
    I've been running 258.96 since the summer with no issues. Eric, I'd be surprised if you could use hardware acceleration using the 191.07 driver. There was a later driver that let me run hardware acceleration, I don't remember which one and I can't look up my old post because, well, you guys know why.
  1. Revit Hardware : General
    By iru69 in forum Hardware and Infrastructure
    Last Post: July 9th, 2020, 05:09 AM
  2. Revit Hardware : CPU
    Last Post: May 14th, 2020, 10:39 AM
  3. Revit Video Tutorials for beginners
    By JCM in forum Tutorials, Tips & Tricks
    Last Post: June 20th, 2011, 11:59 PM
  4. Revit 2012 assemblies - CADclips video
    By willsud in forum Tutorials, Tips & Tricks
    Last Post: May 4th, 2011, 11:08 PM
  5. Best graphic card for Revit 2011 for less than $250 ?
    By Munkholm in forum Hardware and Infrastructure
    Last Post: December 14th, 2010, 11:58 AM
