Thread: Surface Patterns are not displayed.
    March 7, 2012
    9
    01:17 AM
    I have set material and Surface Pattern as 'tile' at the floor. (Uploaded Image)
    Cut Pattern is O.K. But the Surface pattern is not displayed. (visual style : hidden line, Detail Level : Fine)
    and It's black when visual style is 'Shaded'.
ID:	7237Click image for larger version.
ID:	7238Click image for larger version.
    March 7, 2012
    9
    01:17 AM
    Sorry. I found the answer.
    Visual/Graphic > Floor > Pattern was set to Hidden.
  1. grid heads to be displayed differently in plans and elevations
    Last Post: December 12th, 2011, 12:52 PM
    Last Post: October 17th, 2011, 06:15 PM
  3. Import hatch patterns from autocad. Export patterns from drafting to model.
    Last Post: June 15th, 2011, 09:56 PM
  4. Wall surface Patterns on Level Below
    Last Post: April 22nd, 2011, 09:57 PM
  5. Projection Patterns and Lineweights on Floor surface
    By ptranberg in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 08:04 PM
