Thread: structural cables
    August 31, 2011
    160
    07:40 AM
    structural cables
    how would i show cables that are holding up a ramp. the cables would be hanging off a building and connected to a ramp . what is the easiest way of showing this does anyone know?
    Member feio's Avatar
    Decadent Lisbon
    450
    07:40 AM
    Model Lines?
    Will you schedule them?
    If so, I would go for adaptive components w/ just 2 points...
    07:40 AM
    Definately Adaptive components...
    10,790
    01:40 AM
    Any Family can be a cable.
    Non-adaptive component, non-line-based = Youll have to place it on a work plane, then snap the two "ends" with the align tool, to the correct support.
    Non-adaptive component, Line Based = You'll have to place it on a work plane, then "draw a line" where the cables go.
    Adaptive component = It can be two point (line) or three point (spline), which will allow you to snap in 3D, and make it seem like its in *tension*, with the third point. You can do that with a Line Based as well, if you build in some math.
    Just depends how you want it to work. They all have their ups and downs. AC's based on things in the rest of the model, get a little ugly if the things theyre based on in the model suddenly disappear...
    Decadent Lisbon
    450
    07:40 AM
    Maybe its a job for the new divide path tool...
  1. Structural Settings
    Last Post: March 16th, 2012, 10:08 PM
  2. structural framing tag
    Last Post: December 6th, 2011, 06:59 PM
  3. Structural Detailing
    By Alex Cunningham in forum Structure - Interoperability
    Last Post: August 26th, 2011, 04:09 PM
  4. Structural Foundation
    By cherub65 in forum Structure - Family Creation
    Last Post: May 4th, 2011, 07:30 AM
