Thread: Hide or Rezise Connectors in Preview
    Member troygates's Avatar
    December 17, 2010
    Southern California
    143
    04:48 AM
    Question Hide or Rezise Connectors in Preview
    In my quest to build an MEP library of families, I am finding that the size of the connector symbols cause the family preview to be unusable for small objects. See attached image. Has anyone come up with a trick to hide the connector or resize it so that the family preview looks like the actual object instead of a circle crosshair?
    3,167
    04:48 AM
    In Revit 2013 I find that I can use Temporary Hide/Isolate > save the file and close it. The preview I get afterward respects the state of the view and doesn't show the connectors.
    Edit: Just tried it in 2012 too...works.
    December 17, 2010
    Southern California
    143
    04:48 AM
    Got it to work in 2012 also, thanks Steve.
    These seems like a bug, but a handy one all the same. I always figured that the temporary visibility settings weren't saved in the model since they are gone when you re-open the model. But appears that Revit might be storing them in memory until the model is closed so the view is saved with the temporary visibility settings intact, but then they are lost once the model is closed.
    May 25, 2011
    192
    06:48 AM
    Select one connector and type HC (hide category)
    3,167
    04:48 AM
    Quote Originally Posted by Randy_CaS View Post
    Right click - Hide In View isn't available in the family editor environment last time I checked. HH will fire up Hide Element though, part of Temporary/Hide Isolate's "toolbelt". Hide Category in Temporary/Hide Isolate is disabled when you select connectors for some reason...otherwise it would be true.
    May 25, 2011
    192
    06:48 AM
    I do not have 2013 here to test, but in 2010 I use it alot. I was surprised when typing "HC" worked since there is no underscore that would imply the feature works. Notice in the image all types of connectors are hidden, not just the type of connector selected.
  1. Hide element, but keep the Tag?
    Last Post: September 18th, 2014, 11:35 AM
  2. Workflow - Arraying Connectors
    Last Post: February 1st, 2012, 12:07 AM
  3. Hide Flip Controls
    Last Post: October 31st, 2011, 10:22 PM
  4. Connectors and nested faces
    Last Post: June 21st, 2011, 03:59 PM
  5. How to hide cut profile cut lines
    Last Post: April 28th, 2011, 11:58 AM
