Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Demolish Ceiling Grid and dashed lines
  1. #11
    Forum Addict sdbrownaia's Avatar
    December 20, 2010
    1,152
    09:22 AM
    you have to have the original text file of the pat to change the numbers. But you should be able to modify these as needed.
    *2X4 Demo,tip118-Ceiling grid-CADalyst,Vol.3 #5-Nov.1986-Tip #118-by Chris Garman
    ;%TYPE=MODEL
    0, 0,0, 0,48, 24, 4, -4, 8, -4, 8, -4, 8, -4, 4
    90, 0,0, 0,24, 48, 4, -4, 8, -4, 4
    *2X2 Demo,tip118-Ceiling grid-CADalyst,Vol.3 #5-Nov.1986-Tip #118-by Chris Garman
    ;%TYPE=MODEL
    0, 0, 0, 24, 24, 4, -4, 8, -4, 4
    90, 0, 0, 24, 24, 4, -4, 8, -4, 4
    Wherever there is a 24 change to your desired spaceing ie 12 for 12" and wherever there is a 48 change it to 72 if you had a 12 x 72 pattern or whatever
  2. #12
    January 19, 2012
    348
    07:22 AM
    Attached are the Patterns I use.
  3. #13
    January 26, 2017
    05:22 AM
    Quote Originally Posted by rosskirby View Post
    Here ya go.
    It worked great, thanks, amazing how Revit hasn't figured out how to do demo ceilings.
  4. #14
    3,250
    06:22 AM
    It demos ceilings the same way it does everything. It doesn't demo fill patterns on anything. Ceilings are obvious but its the same issue for a brick wall... Materials using patterns and assigned to elements by type demand a unique type to define demolition.
    Further complicating it is the sketch based approach to ceilings (and roofs). When we demo some of a ceiling we have to take care to create ceilings discreetly so the portions that must be demolished can be altered separately. Its not very different from splitting a long wall into shorter segments so portions of the wall can be demolished.
  5.    #15
    April 29, 2021
    07:22 AM
    You are wonderful to have shared this revit file! Grateful!
  1. Centering ceiling grid
    By GMBailer in forum Architecture and General Revit Questions
    Last Post: February 7th, 2018, 08:23 PM
  2. Replies: 4
    Last Post: August 7th, 2014, 08:54 AM
  3. Ceiling Grid on my lighting sheets.
    By DMapes in forum MEP - General
    Last Post: May 10th, 2012, 09:13 PM
  4. ISO View Grid Lines.
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: January 6th, 2012, 02:15 PM
  5. Revit OpEd: Ceiling Grid in Navisworks
    By Revit OpEd in forum Blog Feeds
    Last Post: August 22nd, 2011, 03:00 PM
