Thread: Name category of views
    Russian Moderator
    Russia, Rostov-on-Don
    30
    02:05 PM
    Hi, all !
    In project based on russian tamplate, in project browser I see "Name of category of views" (see attachment), but in project based on empty template this is not.
    If it possible...
    How I can change this "names" in an already prepared templates (or in project) ??
ID:	1016   Click image for larger version.
    11:05 AM
    This is done by setting the sorting order for the views. In the empty template the "All" hardcoded sorting order is used, in the russian template there's probably a custom sorting order used (the name of the used sorting order is given in brackets behind the top line "Views". To change this, right click on the Top Line in the project browser (Views) and select Type Properties. Change the Type to something else then "all". You can keep this, or select Duplicate (watch out: Duplicate is greyed out in the type "all" but not in other types). Then you can change the sorting order of views and folders.
  1. Crop Views?
    Last Post: February 24th, 2016, 09:23 PM
  2. Shared Parameter Category
    Last Post: May 24th, 2011, 11:39 AM
  3. Creating Views
    By cwwalder in forum MEP - General
    Last Post: February 9th, 2011, 05:51 PM
  4. Details with 2 views
    Last Post: February 9th, 2011, 12:30 AM
  5. Creating views
    Last Post: January 18th, 2011, 03:24 PM
