Thread: Project Upgrade to 2012 - Spare Circuit Breakers
    Member Steven Thedens's Avatar
    May 2, 2012
    Omaha, Ne
    61
    05:52 AM
    We've upgraded a project from Revit 2009 to 2012. Now the Spare circuit breakers cannot be edited, except for renaming. What we'd like to do is remove them and place a loaded breaker in its place. Has only else encountered this and/or resolved it?
    "OMG I killed Revit"
    dzatto's Avatar
    5,273
    05:52 AM
    I'm on 2013, and am just starting to dabble in the MEP side of things (usually use RAC), so this may not help you. But, if you select the spare in the panel schedule and look up in the ribbon, is there a command to "remove space / spare"? That removes it in 2013. Then, you can create a new circuit and use the move commands (in the ribbon) to put it where you want it. Not sure how 2009 and 2012 are set up, I don't have them loaded anymore.
  1. how to upgrade existing project to my new template?
    Last Post: March 14th, 2015, 03:05 AM
  2. multiple circuit tags
    By chris.macko in forum MEP - General
    Last Post: July 12th, 2013, 10:27 PM
  3. Inside the System: Upgrade Your Project from 2012 and Get Loopy!
    Last Post: April 13th, 2012, 12:15 PM
  4. How do I upgrade RAC 2011->2012?
    By cwalker in forum Architecture and General Revit Questions
    Last Post: October 17th, 2011, 06:37 PM
  5. Upgrade to 2012 Deletes Ceiling Type Mark Info?
    Last Post: October 6th, 2011, 09:27 PM
