Thread: Drawing Sheets - CAD TO REVIT
    Senior Member domsib's Avatar
    April 30, 2012
    586
    02:38 PM
    Hello,
    We are in the process over moving over from AutoCAD & working on REVIT for a few projects. I am the CAD Engineer for my company & I have been tasked with getting to grips with REVIT. We are on 2011 at the minute but are in the process of upgrading to 2013.
    I have just done a brief 3 days course on the basics of REVIT but the first thing that I would like to do is bring over our drawing borders we use in AutoCAD to REVIT.
    Does anyone have any information, advice, guides etc on the best way to set up drawing borders A0,A1 etc. As I mentioned we have all these templates for AutoCAD so if there is a simple way to make these work in REVIT then please share.
    Thank you
    April 25, 2011
    Egypt
    752
    02:38 PM
    It is simple click on the view tab or on project browser --- new sheet -- load your sheet .
    You can make also your custom sheet if neither of these sheets complying to what you want
    and to make it just click on the R -- new -- Titleblock open the size and adjust it or make custom one by building lines or typing text.
ID:	8680   Click image for larger version.
ID:	8681   Click image for larger version.
ID:	8682   Click image for larger version.
    Last Post: April 15th, 2012, 04:26 PM
  2. Drawing a polygon with revit API
    By Habib in forum Third party Add-Ins, API and R&D
    Last Post: February 29th, 2012, 07:30 PM
  3. Revit sheets to PDF ?
    By Devlin in forum Architecture and General Revit Questions
    Last Post: February 7th, 2012, 03:28 PM
  4. Drawing 3d Pipes in Revit Architecture
    By rickbern in forum Architecture and General Revit Questions
    Last Post: August 29th, 2011, 10:30 PM
  5. Separating drawing into two sheets crop view problem
    Last Post: April 14th, 2011, 09:05 PM
