Thread: Pipe Size Incorrect
    "OMG I killed Revit"
    dzatto's Avatar
    5,236
    04:02 AM
    Pipe Size Incorrect
    Why does my 1/2" pipe show the size to be 1" (under dimensions in it's properties). These are OOTB cold water pipes. It seems everything rounds to the nearest inch. 1.25 is 1". 1.5 is 2" and so on. This makes tagging the pipes pretty useless. What am I missing?
    March 20, 2012
    Austin, Texas
    224
    04:02 AM
    Check under Project Units -> Piping -> Pipe Size and make sure the Rounding is set to something appropriate like 1/8". If that doesn't work, check under Mechanical Settings -> Pipe Sizes and look at your pipe diameters there.
    dzatto's Avatar
    5,236
    04:02 AM
    Aaron, you are quickly becoming my MEP teacher.
    Project units was the culprit. Working in architectural all the time, I never had to change anything other than the "common" units.
    Why the hell would they default pipe sizing to the nearest inch?
    March 20, 2012
    Austin, Texas
    224
    04:02 AM
    Why the hell would they...
    Glad to help! This is a question you'll be asking yourself often in the Revit MEP world.
    3,159
    04:02 AM
    Why the hell would they default ANYTHING to the nearest inch?
    FTFY
    (Says the won't-let-me-type-a-short message)
  1. Curtain Wall Door reporting incorrect level
    Last Post: August 3rd, 2018, 06:11 PM
  2. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 02:56 PM
  3. Replies: 1
    Last Post: May 20th, 2012, 09:26 AM
  4. Pipe/Duct Size Tag - Secondary Units
    By richardfrenette in forum MEP - General
    Last Post: March 7th, 2012, 07:04 PM
    Last Post: July 14th, 2011, 12:11 AM
