Results 1 to 9 of 9
Thread: Door not displaying Room information in schedule
    January 6, 2011
    64
    07:56 AM
    I have a door which will not display the 'to room' or 'from room' information in the door schedule. The door is a stand alone door (operable wall) ie. does not need to be hosted by a wall which I'm thinking is the cause of the problem. Is there any way to get around this, short of recreating the entire door as a wall hosted family?
    3,291
    04:56 PM
    You guessed correctly.
    A Door really doesn't know what it's To Room and From Room are.
    What happens deep in the bowels of Revit is that a Door knows which Wall is hosting it, and the Wall knows what Rooms are on either side of it.
    So, yes, your door will need to be wall hosted.
    Depending on how complicated it is, you might be able to nest your current door into a hosted door family and Share it to exposed the parameters
    January 6, 2011
    64
    07:56 AM
    Thanks Dave.
    February 20, 2011
    Sofia, BG
    36
    12:56 AM
    Actually Door and every other family knows to what room it belongs. But you can see this info only through the Revit API.
    best regards
    Junior Member mruehr's Avatar
    March 16, 2011
    Perth Australia
    17
    05:56 AM
    Quote Originally Posted by brett05 View Post
    Nest the operable wall family into a curtain wall Door Panel Family and use it in a curtain wall and all should be fine.
    That’s how I do my operable walls
    There is a pretty good example on BIM Objects / Families ::
    January 6, 2011
    64
    07:56 AM
    Thanks guys. I ended up nesting it into a normal wall hosted door family and it now works fine. It means an extra step by having to create a wall, but at least it's scheduling as I require it now.
    Auckland, New Zealand
    618
    09:56 AM
    Can I ask a stoopid question? why are you using rooms if there are no walls (to host a door in)?
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    248
    12:56 AM
    Quote Originally Posted by Tim West View Post
    Maybe because it is something like that? Click image for larger version.
    618
    09:56 AM
    Quote Originally Posted by cerb0z View Post
    Thanks!
    It appears that all stoopid questions get stoopid answers!!?!
    Your image suggests that there is no 'to room' or 'from room' though as the panels are hinged at their centre...
    There must be some crazy steel in them there ceilings...
  1. Door From/To Room Value in Schedule
    By pfaudler in forum Third party Add-Ins, API and R&D
    Last Post: December 10th, 2016, 09:37 PM
  2. Door properties "From Room: Number" does not change when door flipped
    Last Post: September 19th, 2012, 07:48 PM
  3. Door tags and Room numbers
    By ncebula in forum Architecture - Family Creation
    Last Post: May 17th, 2012, 09:28 PM
  4. Extract scheduling information on door casing
    By Pashcal in forum Architecture and General Revit Questions
    Last Post: May 9th, 2012, 08:41 PM
