Thread: Wye Connection off sloped main pipe
    37
    08:03 PM
    I'm on the architectural side of things playing with RME so i'm not really too familiar with this (although have read the shortcomings of sloping pipe):
    I'm having trouble getting a clean WYE connection off the sloped main. It seems to add all these extra fittings when I try to slope a branch off of it (un-sloped as well).
    The only way I can get this to work is using Connect Into directly from the fixture to the main. It only goes in a straight line and it doesn't slope (I have to slope it afterward). I then split straight branch pipe, pull it back and angle it in plan and move it down the main run, then trim it back to the straight branch.
    Although I can get to the desired result, I'd like to be able to draw directly off the main and then to the fixture without all these extra fittings. First two images are how I want it to look, the next two are the result of drawing directly off the main sanitary line.
ID:	1105Click image for larger version.
ID:	1106Click image for larger version.
ID:	1107Click image for larger version.
    December 23, 2010
    Albany, Oregon, USA
    59
    06:03 PM
    Brett,
    Which fitting are you using for your Wye? It looks like the Sanitary Tee, which can give mixed results when not used at 90░. A Wye fitting should come off at a 45░ angle, and there is one in the OOTB library.
    John
    37
    08:03 PM
    John,
    Thanks for the reply. I tried out the WYE fitting. What I did was first place the WYE fitting on the main sloped pipe first and then draw sloped pipe from the WYE fitting to the fixture. Works great.
    I would like to be able to draw pipe directly off the main without having to place the fitting first though. I edited the WYE fitting, changed its part type to TEE in (Family Category and Parameters). Set it as the Tee type in the PVC Pipe Type. I then draw off the main - same result as above. Weird thing is if i delete the extra fitting and then draw directly from the fitting, it works fine. Its like it doesn't rotate itself properly for the slope orginally. This happens with all angles even 90 deg.
    Would really like to be able to just draw directly off the main without placing a fitting first then having to draw.
    December 23, 2010
    Albany, Oregon, USA
    59
    06:03 PM
    Brett,
    I think i know what the problem is. I repeated the steps you went through and everything worked fine for me, but I was able to reproduce your result by not acquiring the pipe elevation when drawing the branch off the main. When you start drawing the branch at your 45░ angle (come off the main an arbitrary distance) and press the space bar. If you watch the elevation indicator, you will see that the start elevation of the pipe changes. This starts the pipe at the exact elevation of the fitting and will eliminate the extra "offset" fitting that gets added.
    John
    37
    08:03 PM
    John - that worked, I was missing the spacebar step to acquire the elevation. Thanks for taking the time.
  1. Down Pipe Creation
    By Scott_CJDH in forum Architecture - Family Creation
    Last Post: October 28th, 2016, 04:54 AM
  2. Creating a Pipe system
    By DHelton in forum MEP - General
    Last Post: August 9th, 2011, 02:28 AM
  3. Sloped Pipe Question
    By jhenry58 in forum MEP - General
    Last Post: August 2nd, 2011, 08:57 AM
  4. Wall connection
    Last Post: May 27th, 2011, 03:46 PM
  5. sloped roof connection between two parts
    Last Post: May 19th, 2011, 10:50 AM
