Thread: single parameter re-size sweep-blend based on locked angle constraints
    July 12, 2012
    10
    02:12 AM
    Hello
    I am creating a splayed skylight with 3 splayed walls and a single vertical wall (2'-4"always). I have created it using a swept blend with two perfect squares, and then cropping the top at the design (altitude) angle. This creates a trapazoidal "window" at the top of the skylight with a square base. (see the attached picture).
    I would like to be able to size this parametrically using the base length (profile 1 of the swept blend). When I try this, however, the angle constraints are not maintained because the path length and (top) profile 2 do not move and size with the parameter (the profile 1).
    My end goal, however, is to create several types of skylights all with a trapazoid of area 9 SF (or as close to it as possible), with varying altitudes (in the picture, this is angle 55 degrees) I thought to do this by trial and error, varying the bottom square and then find the area of the top trapazoid and then adjust and repeat. If there is a way to size it based on the altitude angle and end area of the trapazoid, that would be ideal.
    PS. I know that I could work in CME, but I chose to work in generic family modeling for speed.
    Thank you for all the help you can offer
    -ArielClick image for larger version.
    6,333
    05:12 AM
    Odds are it will involve multiple formulas - if you havent seen it, look here: http://www.revitforum.org/tutorials-...day-usage.html
    Past that I am terrible at that type of thing and can't offer much help
    3,226
    05:12 AM
    This family is complex, due to all the requirements that you have listed: 3 slanted wall sides, one vertical wall side, a square base, a right angle at the top of the section view, and a top surface that is a trapezoid, slanted, at a variable angle, at a certain height, and with a certain area: 9 sf...
    It would be very difficult to do it with just the 'standard' families. It's better if you combine families from the standard and the 'adaptive' template, where you can control the top of the prism with a true parametric trapezoidal family.
  1. Revit Server - Locked Files
    By snowyweston in forum Worksharing, Revit Server & C4R
    Last Post: May 9th, 2012, 05:54 AM
  2. Blend Too Thin
    Last Post: April 3rd, 2012, 08:00 PM
  3. locked wall layers
    By Pickens in forum Architecture and General Revit Questions
    Last Post: February 14th, 2012, 04:07 AM
  4. Face Based VS Wall Based VS Non-Host with Void Families
    Last Post: December 16th, 2011, 04:20 PM
  5. Face Based Wall Cut Angle and/or Curtian System Corners
    Last Post: April 4th, 2011, 07:38 PM
