Thread: Bump: help needed
    Nantes, France
    1,381
    09:55 AM
    Question Bump: help needed
    hi all,
    I try to have a bump effect on a material (concrete wall), but each time I render, the surface looks like a mirror, no bump at all.
    Tips and ideas will be welcome.
    Kingdom of Denmark
    4,305
    09:55 AM
    Julien, can you show some screen dumps? or even better yet, strip down a copy of the project, and post it here?
    Nantes, France
    1,381
    09:55 AM
    yep, I will, but I'm on the road. Will post later. see you
    Moderator mark b's Avatar
    NSW Australia
    1,437
    06:55 PM
    Did you try winding up the bump scale. The default "Concrete - Cast-in-Place Concrete' render bump map usually defaults around 320x320mm which is usaually to small a scale and comes out "flat", if you have a play with the scale around 900mm to 1200mm you start to get some bump happining. The Concrete - Cast-in-Place Concrete default render mat. is a reasonable material to start with
    Can't say I like any of the standard conc materials shipped with Revit. Arroway do some great render materials.
    NSW Australia
    1,437
    06:55 PM
    I have noticed that the few "Concrete - Cast-in-Place Concrete' materials that have bump maps associated with them, both images come in at different scales so well worth checking both image scales before loading.
    07:55 AM
    Check the scale of the bump
    Check the amount of bump (one time had it set to 0, doesn't really do anything in this case)
    Check the repeat settings of the bump pattern
    Nantes, France
    1,381
    09:55 AM
    thanks all, I got it. scale was the issue.
  1. Help Needed: Data Extraction From Revit
    By akarthick in forum Third party Add-Ins, API and R&D
    Last Post: November 19th, 2018, 09:28 PM
  2. Help needed making a 3D Arched Building
    By Steven82 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 14th, 2011, 05:51 PM
  3. Approval & help needed
    By mdradvies in forum Third party Add-Ins, API and R&D
    Last Post: May 11th, 2011, 10:19 AM
  4. DD Architect needed for Shanghai firm
    By Dennis_n in forum Career Corner
    Last Post: April 22nd, 2011, 08:54 AM
  5. Re: rendering + bump map + relief + metal surface
    By jonathanlarocca in forum Rendering and Gallery
    Last Post: January 7th, 2011, 09:26 PM
