Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: I need Best Practice Advice for sharing the model with consultants
    Forum Addict Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    1,015
    11:11 PM
    Currrently we will use our ftp to post the model for our consultants.
    What is 'Best Practice' when preparing the model.rvt for sharing with consultants? Should I purge all families, sheets, views,....what should I jettison and what should I keep?
    -Chuck
    11,164
    03:11 AM
    Keep everything, dont change a thing, upload, and keep on truckin.
    December 6, 2011
    Fairbanks, Alaska
    1,015
    11:11 PM
    Thanks Aaron, I'll send out as is,...I did however, create an additional title block without stamps, then purged the title block with stamps from the file to be posted.
    11,164
    03:11 AM
    Quote Originally Posted by Charles Karl View Post
    Gotcha. We dont keep those in there, but yeah... Would probably take those out.
    4,443
    09:11 AM
    "Stamps" as in company titleblocks? To prevent others printing drawings from the model I presume?
    Member AHutchinson's Avatar
    September 19, 2011
    Spokane, WA
    232
    01:11 AM
    I'd assume that its the security of having the architects stamp floating around, possible even with a signature, which is why I link it in once and copy to selected sheets, then after printing and making sure that everything is fine, I can manage links and remove.
    Junior Member jason.karam's Avatar
    July 9, 2012
    Portland, OR
    27
    01:11 AM
    We also have our stamps (and some digital signatures) in our title block. Purging them all out then uploading the file would be the best idea. Don't want those stamps circulating... i've forgotten to purge them out of cad files before...:s
    December 6, 2011
    Fairbanks, Alaska
    1,015
    11:11 PM
    I set up a yes/no parameter for 3 different architects stamps using an annotation family, inserted in the title block, one over the top of the other. Visibility is controlled per sheet by checking or unchecking a box in the properties pallet in the catagory of 'Other'
    "OMG I killed Revit"
    dzatto's Avatar
    5,275
    03:11 AM
    Why worry about the seal, as long as it doesn't have a digital signature? I can easily recreate your seal from a hard copy if I really wanted it. The seal is worthless without the signature.
    May 18, 2011
    Calgary, AB
    443
    02:11 AM
    I use image files of the stamps with signatures.
    Get it lined up on one titleblock, copy and then paste using "aligned to selected views" and select all the sheets I want.
    Pdf the set.
    Then use Manage images and delete the image.
    Case put out a free add-in that will delete your sheets, views and revit links (I think it removes the cad links as well)
  1. Sharing Our Title Block With Consultants - Best Practice?
    Last Post: June 16th, 2012, 10:58 PM
  2. Need Best Practice Advice for Rooms
    Last Post: March 23rd, 2012, 04:57 PM
  3. Need Best Practice Advice for the use of Split Face
    Last Post: March 21st, 2012, 01:53 PM
  4. RFO Blog: Sharing your model: GET OVER IT PEOPLE
    By RFO Blog in forum Blog Feeds
    Last Post: February 3rd, 2012, 01:15 AM
  5. sharing the model
    Last Post: November 7th, 2011, 04:28 PM
